350z vs g35 TEIN S-TECH springs
Old Oct 11, 2006 | 12:44 AM
nyckid's Avatar
do both of these offer the same height of drop on a g35 coupe? or is the 350z version lower, if so, is it a big difference?
Old Oct 13, 2006 | 11:31 AM
Calvin's Avatar
Overglorified Altima
drop is different... spring rate is different...
if there was no difference, why would they make two versions and not just say one is made for bot?
g35 s-techs:
rates: f/r 6.4/4.9kg
drop: f/r -1.2/-0.9
350z s-techs:
rate: f/r 6.9/7.2kg
drop: f/r -1.2/-1.1
Old Oct 13, 2006 | 12:24 PM
eemon10's Avatar
i just put the s-techs on my g35 and it was just like he said: g35 s-techs:
drop: f/r -1.2/-0.9
...i just put them on yesterday...about how long should i wait to get an allignment?
Old Oct 13, 2006 | 04:48 PM
aleok's Avatar
when i had the 350z S-tech i waited 2 weeks for alignment, and didn't get back into specs. the drop is BASICALLY the same, but the spring rates are much better.
Old Oct 16, 2006 | 04:05 AM
nyckid's Avatar
i'm aware of the difference, but i'm just wondering if there's a difference in height... no need to roll your eyes.
Old Oct 16, 2006 | 04:13 AM
Klubbheads's Avatar
Tein S-tech 350z (fronts are progressive, rears are linear) .7”/.6” drop on 350Z G35 coupe drop will be 0.5 inch higher and 1.0 on the sedan
Spring rates in lbs 386/402 (final rates only, softer initial front progressive rate unknown)
Stiffer then oem by F+23% R+16% (see note at very top)
Tein S-tech G35 coupe & sedan (fronts are progressive, rears are linear)
Spring rates in LBS 358/274 (final rates only, softer intial front progressive rate unknown)
Stiffer or softer then oem springs by R+14% R-18% (see note at very top)
Old Nov 11, 2006 | 01:48 AM
dvsmeth0dz's Avatar
would i need a camber kit if i used 350z stechs on a 06 coupe?
Old Nov 11, 2006 | 05:05 PM
GreenGoblin's Avatar
The goblin resurrection
I have the s techs for a g35 and I am very happe with them
Old Nov 11, 2006 | 05:29 PM
Calvin's Avatar
yes, youll want to get one. generally, anything more than an inch will require a camber kit to get you back into specs.
Old Nov 11, 2006 | 05:31 PM
Calvin's Avatar
did you read my post at all then?
i posted the difference in drop height...
g35 s-techs:
drop: f/r -1.2/-0.9
350z s-techs:
rate: f/r 6.9/7.2kg
drop: f/r -1.2/-1.1
Old Nov 12, 2006 | 05:32 AM
he was just skimming he needs the clif notes
Old Nov 14, 2006 | 04:22 AM
Pro-Skyline03's Avatar
ok so nothing will happen if you put 350z's tein s-techs lowering springs on your G35 correct?? cause i just bought my friends springs he had bought for his 350z but he never put them on the car....
Old Apr 2, 2011 | 09:52 PM
or_G's Avatar
so do you think the 350z ones would be a better buy because it's stiffer than OEM?
Old Jul 5, 2011 | 12:59 PM
buzzking's Avatar
The 350z stechs will drop your G more than the g35 stechs.
I recommend you get a rear camber kit.
Old Jul 7, 2011 | 01:45 AM
Gsedan35's Avatar
You've already gotten the drop height question answered. But I have a question.
Was your G35 coupe delivered on oem 17, 18, or 19 inch wheels?
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
VANST3R
Lights
Jul 27, 2015 08:20 PM
laksjd84
Jul 24, 2015 05:12 PM
netcbc
Engine - Intake/Fuel CDN
Jul 24, 2015 02:21 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
