suspension question
Old Oct 12, 2006 | 10:38 PM
maicoJr's Avatar
suspension question
I am looking to purchase Tein Basic coilovers and was wondering if i can reduce the negative camber with an alignment? Or is the only way to reduce the negative camber is by buying a camber kit?
Old Oct 14, 2006 | 09:35 PM
dklau33's Avatar
this is true for the front
Old Oct 15, 2006 | 07:49 AM
aleok's Avatar
if you buy tein coilovers, and don't lower it, and keep at stock height you don't need a camber kit. but if you drop more then an inch, you should get a camber kit.
Old Oct 18, 2006 | 11:37 AM
Gilley's Avatar
The rear has a little camber adjustment but not much, so you will likely need camber arms if you lower it more than an inch or so. The front has not camber adjustment, so you just have to hope it settles within specs.
jsimonk
Dec 22, 2023 03:49 PM
rezendvous420
May 31, 2020 01:26 PM
privatecorye
Steering & Suspension
May 31, 2016 01:56 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
kinetek
Aug 3, 2015 04:25 PM
