lowering problem..please help!
Old Oct 17, 2006 | 12:22 AM
diablo1356's Avatar
i need some help on this one...i noticed today that my front drivers side sits higher than all the other wheel wells...i have my car lowered on 350z unrev springs and it caused a nice drop all around but not as much on the front drivers side...anyone else have this problem?...it was like that before i put the springs on and i guess i didnt notice it until today...is it due to less weight on that side of the car?...anyone have any suggestions on how to remedy this?
Old Oct 17, 2006 | 12:46 AM
diablo1356's Avatar
bump..i really need some info guys..
Old Oct 17, 2006 | 01:25 AM
borahatch's Avatar
I'm dropped on 350z h-techs and I have the same issue except its my front passenger side. All other sides have dropped nicely over the past few weeks but the right front is remaining high. Any ideas?
Old Oct 17, 2006 | 12:56 PM
diablo1356's Avatar
bump...come on you suspension gurus!
Old Oct 17, 2006 | 01:53 PM
sen_jen's Avatar
Meatshake Enterprise
do you ride dirty, and rip the potholes?? if so, check your suspension components. you may have a bent aluminum part. not the a arms, but the knuckle might be bent. thats all i can think of since you aint running cut springs. the only way to check if the knuckle is bent is to take it in so it can be measured and compared to oem specs.
Old Oct 17, 2006 | 02:11 PM
drunkin master's Avatar
I have seen this happened to lots of cars, not just the g's. I had springs and my rear pass. side was riding higher. Check to see if the spring and shock are on correctly. I did'nt find an answer for my rear but I ended up getting coilovers and took care of that problem.
Now, the front is pretty straight forward but just double check on the install. Might be the shock too. If you are running stock.
KruZZe
Feb 27, 2023 05:04 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
g.spot
May 9, 2016 10:54 PM
DRG35R
Jan 31, 2016 07:14 AM
