Question about M45 Wheels on G35 sedan...
Old Oct 24, 2006 | 12:25 PM
JKB32's Avatar
I have been told I will need a spacer to make these fit on my 06 Sedan. Just want to make sure on the size spacer that needs to be used for these wheels to fit right. Any help will be greatful. Also did anyone have to use longer wheel stud also. Thanks
Old Nov 4, 2006 | 07:35 PM
6mt-driver's Avatar
Any idea what the offset on the stock wheels for the sedan and M45 are?
Old Nov 4, 2006 | 07:51 PM
aleok's Avatar
^50
Old Nov 4, 2006 | 08:06 PM
GEE35FX's Avatar
M45 19" wheels are 50mm offset.
06 G35 Sedan wheels are 45mm offset.
Old Nov 5, 2006 | 08:37 PM
godmans's Avatar
People usually use 5~10mm spacer at the back to prevent "inner" rubbing
Old Nov 6, 2006 | 02:34 AM
codeflux's Avatar
you will need to use 5mm spacers in the front to avoid having the wheels rub on the shocks. i would also highly recommend using the longer nismo bolts in the front. otherwise, it will be a direct fit.
rezendvous420
May 31, 2020 01:26 PM
911Turbo
19 Inch
Aug 24, 2016 08:31 AM
kinetek
Aug 3, 2015 04:25 PM
laksjd84
Jul 24, 2015 05:12 PM
Detailed Image
Jul 24, 2015 12:31 PM
