New rotors- slotted vs. drilled- Opinions??
Old Nov 3, 2006 | 10:11 PM
  #31
vt_maverick's Avatar
Anybody got pics of slotted/xd rotors on their 03-04 G for comparison? I've seen a couple drilled pics here and there, but I don't know that I've seen a slotted or slotted and xd pic.
Maybe that would help you firm up your decision...
Old Nov 3, 2006 | 11:46 PM
  #32
Skyline_G35's Avatar
English dude, English
Go slotted. They won't crack like the drilled.
Old Nov 4, 2006 | 02:11 AM
  #33
hayaku's Avatar
When I purchased brakes, I talked to StopTech engineers who reccomended slotted for track use, not cross drilled. As they sell both cross drilled and slotted for the same price, there is no reason for them to be biased either way. I would take the word of an engineer specializing in brakes over hearsay over the forums.
Old Nov 5, 2006 | 02:03 AM
  #34
ttrank's Avatar
Grocery getter
Originally Posted by Bluestreak
Right now I'm leaning toward the drilled, because I'm not taking my car to the track, and I'm shallow enough to want the stares that go along with the drilled rotors (as if the calipers alone don't get enough attention on the street). Some of you mentioned having drilled without problems, so I'll probably go that route. However, I have a couple of months to waver back and forth a few dozen times before I pull the trigger...
Nothing wrong with wanting the looks too. I was under the assumption you wanted to track your car. If you are just doing street and mild track driving you will be just fine.
Old Nov 5, 2006 | 05:31 AM
  #35
G35BASTARD's Avatar
Here's a little info i found fellas...
The reason for the creation of cross drilled rotors initially was to remove the "gasses" from the brake pads. HOWEVER, most of your modern brake pads (Axxis metal, AEM semi-ceramic) do NOT produce gasses when heating. This was on bad brake pads used in the 1950s and 1960s. Back then, asbestos was also used, and we dont use that either.
The other reason is so called heat dissapation. I don't have my physics and thermo books with me, but the logic is that the holes in the rotor are suppose to allow the brake pad to cool. So...air gets into the rotor from the inside of the vents. If you have a back rotor which is solid, air gets into these holes how? If your stopped, you are leaving air inside these holes sandwiched between the pads, thus creating air with a rising temperature. Its increasing in pressure from the heat, which I guess you "could" call a gas that would affect braking. So the cross drilled rotors do not remove any gasses formed by brake pads (because there are none created anymore) but could possibly inhibit the creation of "hot spots".
Cross drilled rotors have LESS contact area because of the holes.
But if the rotor is cooler, its better, right? Well no, because these rotors are not cooler. THe heat is generated from the pad/rotor contact. What removes heat the most effectively? When stopped or moving, the pad transfers heat into the rotor because its made of cast iron. the rotor has a lot of surface area and even vanes in it. But the little holes allow air in this surface contact, and you can transfer more heat into a solid big *** chunk of cast iron more than you can into the air. Don't believe me? Touch some steam at 150 degrees, then touch a piece of hot metal which is at 150 degrees. Which burns your hand? the metal. So let the heat transfer into the metal, because since it has so much more surface area, dissapates better.
Safety!!
Cross drilled rotors can crack! I have seen them!!
Even racing teams will reccomend AGAINST cross drilled rotors:
http://www.livermoreperformance.com/...ke_rotors.html
Companies that sell cross drilled rotors that are redrilled may not be structurally sound. I have actually seen pictures of rear Integra rotors that have had hairline cracks turn into the rotor actually breaking apart!
Do your homework. Even Porsche and Ferrari will admit that the cross drilled rotors they use are for looks. So if you are one of those kids who thinks the little holes look cool, get a name brand drilled rotor like Ferrari does. The REASON Ferrari's 'holed' rotors are alright to use is because they are CAST with the holes in them, so they are not actually drilled into cast iron rotors. Cheap drilled rotors are not safe, and even the good ones are not necessary. Why do Ferrari do it? People THINK they want it, and it sells. If you don't believe me, go into the business world. You will learn that pretty soon, you can sell utter **** if people THINK its better.
Information I gathered from http://www.pdm-racing.com/products/brakesrotor.html
says:
"KVR Crossdrilled Rotors
Why should you upgrade to cross drilled rotors?
Simply stated, the function of any vehicles brake system is to stop the vehicle. This is accomplished by absorbing the kinetic energy stored in the moving vehicle, and converting it into heat. The friction caused by the brake pad rubbing on the rotor is the source of this heat. The more quickly and efficiently that heat can be absorbed and dissipated, the more quickly and efficiently the car will stop.
There are several contributing factors to this heat reduction. One of the most common sources of heat is from the gases produced by the bonding agents of the brake pad burning off. Under severe braking, this can actually produce a boundary layer of gas that pushes the pad away from the rotor, which can lead to excessive brake fade. The cross-drilled holes or slots in a rotor provide an escape path for these gasses (de-gassing or out-gassing are common terms), and allow the pad to stay in contact with the rotor. As well as de-gassing, cross drilling or slotting will provide better wet weather braking as water is swept through the holes, or down the slots.
A vented rotor can be viewed as an air fan. When in motion, the vents draw air from the center of the rotor outward. This air flow, over an increased internal surface area, effectively dissipates rotor heat. Cross drilling adds to this air flow, as well as providing additional rotor surface cooling. "
This company is just telling you that the rotors may be cooler, however they fail to mention that the holes really do create a more than substantial decrease in surface area, thus less braking, thus less heat created, thus the less heat CREATED will leave the rotors cooler, the holes barely do anything! Its the less braking lowering the temperature!
Slotted rotors-
Find me a company that uses stock slotted rotors. They remove brake dust, but if you study braking systems, you find that with modern cars, flat blank rotors and semi-ceramic pads, the brake dust causing the rotor to slip on it is almost non-existent. But the brake dust doesnt need all those lines. Notice how most front brake pads (and most back) have that line down the middle to give essentially two bite points. If OEM or racing companies found it to be a benefit, they would do it.
PROOF OF IT ALL:
Find me an F1 car as of now that uses cross drilled or slotted rotors.
They all use full ceramic rotors and ceramic pads. Are they drilled or slotted? No.
If they helped the fastest cars in the world, wouldn't they use them? Its basic calculations that show the lack in surface area does not make up for the possible loss in temperarure. They use brake cooling air ducts insted.
IN CONCLUSION:
Don't buy slotted or cross drilled rotors, blank are better, and stop better. Physics people, get me my formulas and help me out here.
If you must get rotors with designs on them, get the slotted ones by a good company, and DON'T get blank rotors redrilled with little holes all over them. IF you absolutly must have the rotors with holes cause you like em, get them from a company that casts the rotors like that. I have seen rotors break and this is for your safety!
Old Nov 5, 2006 | 12:16 PM
  #36
LazerRed1's Avatar
Here is one option. 2 piece to help heat dissapation. Only other thing to do to help rotor life is cryo treating. Also lighter weight to reduce unsprung weight.
http://www.stoptech.com/products/rotors.shtml
Old Nov 5, 2006 | 12:28 PM
  #37
emtguy05's Avatar
i cant decide between Hawk Performance Ceramic (F:$105.98,R:$75.28) or those cryo treated ones...suggestions?
Old Nov 5, 2006 | 12:38 PM
  #38
LazerRed1's Avatar
Isn't the Hawk ceramic, a pad and not a rotor?
Old Nov 5, 2006 | 01:11 PM
  #39
LIUser's Avatar
slotted... more surface area = more friction. friction sotps your car. cross drilled also causes more weak points in which the rotor could potentially crack.
IMO slotted looks better too, more racy. but most will tell you they like the appearance of cross drilled rotors.
either way if you dont track your car the differences youll see are little to none. pick which u like better
Old Nov 5, 2006 | 01:43 PM
  #40
LIUser's Avatar
Safety!!
says:
Slotted rotors-
PROOF OF IT ALL:
IN CONCLUSION:
sorry everyone in advance for quoting this whole thing, but i can tell you why your theory here is flawed.
first of all, f1 cars dont use full ceramic discs, they are carbon and are 278 x 28. by using these discs and pad combinations their capacity for heat is in excess of 1000 degrees Celcius. the air ducts are their form of ventilation, having such a contraption on our G's would be nearly impossible and very pricey, thus we need a source of cooling as well, and slotted/drilled seem to be the ideal setup to cool brakes. the option of using these brakes would be so overly priced and not worth the investment at all.
dont you think companies like stoptech, brembo, and endless would offer a BBK with a large blank disc if what you say was true??? they spend a large sum of money on R&D and im sure they've looked into the possibility, but it just doesnt seem to make sense for the little improvement it would create. to me your logic makes sense, but as far as dissapating heat from the rotors you dont seem to take this into account.
if you would like the scientific approach to this i believe newtons second law of thermodynamics says that energy lost is turned into heat energy and is given off into the atmosphere. gibbs free energy equation also says that the change in systems free energy is equal to the change of enthalpy (the total energy in the system) subtracted by the procuct of maximum temperature in kelvin (C + 273) multiplied by change in entropy (disorder in the system).
both of these are to this date considered to be true, and taking these into account you need to realize that heat will ruin your cars ability to brake efficiently.
hope this helps, i dont mean yo put u down g35bastard, just pointing out somethings that may help
Old Nov 5, 2006 | 02:23 PM
  #41
emtguy05's Avatar
geez i feel like im back in physics class
Old Nov 5, 2006 | 03:06 PM
  #42
LIUser's Avatar
... so ur not paying attention to a damn thing thats goin on???
i hate physics...
Old Nov 5, 2006 | 03:56 PM
  #43
Dan_K's Avatar
Some aftermarket companies, who offer a combination of drilled and slotted, have a lifetime warranty with their brakes against warping or cracking. You just have to look around.
Old Nov 5, 2006 | 04:27 PM
  #44
emtguy05's Avatar
yea my bad, the PC are the pads and the cryo treated thingamagiggers are the rotors
Old Nov 7, 2006 | 01:10 AM
  #45
LIUser's Avatar
so no rebuttle to my comment yet? or do i stand correct?
