Brake Pads Low???
Old Nov 20, 2006 | 11:29 PM
bluestacy04's Avatar
Brake Pads Low???
In the morning now I have a squeek for about 3 minutes. Then they are quiet. Is there an easy way to check if my pads are low. I bought the car used about 4,000 miles ago. its at 46k right now.
Old Nov 21, 2006 | 12:21 AM
sage's Avatar
You can eyeball it through the wheel but the best way is to take off the tire and check since the pads can be wearing unevenly. The squeeking usually is a sign that you need to replace.
If you are uncomfortable checking yourself, you can always take it to the dealership and they usually will check for you since they want your business.
Old Nov 21, 2006 | 12:42 AM
Thanks...I'm looking at the Hawk HPS pads right now.
Old Nov 21, 2006 | 01:24 AM
shodog's Avatar
I would say you need pads. my first set of pads were replaced at 25K and now I need another set at 44K
Old Nov 21, 2006 | 08:24 AM
Q45tech's Avatar
You need a brake micrometer to measure the pad and rotor thickness and a clamp on dial gauge to measure [set] the rotor runout within 0.0005".
Jiggerjuice
Oct 5, 2015 02:33 PM
miata007
Aug 17, 2015 04:36 PM
kinetek
Aug 3, 2015 04:25 PM
sahizzle110
Jul 29, 2015 11:36 AM
EnCr1pt3d
Jul 29, 2015 03:35 AM
