average lifespan of brakes (non-Brembo)
Old Nov 29, 2006 | 10:21 PM
JC-RH's Avatar
does anyone know the average lifespan on non-Brembo brakes? i have a 2006 6MT coupe, and the driver's passenger side is making a soft scratching/screeching sound when i apply the brakes. i have 13000 on the odometer. i have recently popped on a 25mm spacer in the rear, but i do not have any rubbing issues.
how long have you had your brakes without changing the brakes?
the dumba$$ service rep told me that brakes on this car last 10k-15k miles. is this BS or what??
Old Nov 29, 2006 | 10:23 PM
brianmfournier's Avatar
My front pads and rotors went at about 19k, so this dood is not too far off
Old Nov 29, 2006 | 10:24 PM
Texasscout's Avatar
Have the 05' sedan. Got 41K and they'er gettin' close.
Old Nov 29, 2006 | 10:43 PM
JC-RH's Avatar
i also expected the brakes to last 40k+. i dont even abuse my brakes, and i hope that the dealership will cover it.
Old Nov 29, 2006 | 11:39 PM
Q45tech's Avatar
Applications per mile and duration of applications and foot pressure on pedal.
Obviously a lot of difference with all interstate vs all city or ratios of combos of each.
Need a totalizer connected to brake lights to just calculate how many hours [minutes and seconds] are used in some mileage interval.
Old Nov 30, 2006 | 09:33 AM
SilverII's Avatar
my first non-brembo OEM went out at 30K (pads and rotor), replaced it with PMU B-force and now at 46K, it looks to be 1/2 worn, estimating another 16K left.
The rears are still on the first set.
Old Nov 30, 2006 | 10:13 AM
G35lips's Avatar
Florida G35 Club Member
I have an 05 coupe with 25k miles. At my last service they said I had just under 50% life left on my pads. Hopefully I will get 45k out of them. I think alot of it depends on your driving habits. I mostly do highway miles so there usually isn't to much braking involved.
Lips
Old Nov 30, 2006 | 10:46 AM
sillief00l's Avatar
Smile
My non-brembo's needed to be replaced 3 times. I have about 36,000 miles on my car right now. Changing to the OEM Brembo setup soon with aftermarket pads and rotors.
Please tell me I am an aggressive driver.
Old Dec 9, 2006 | 01:30 PM
SFG356MT's Avatar
24k on stock pads and about 55% life left on the pads. I drive a lot of city and aggressive at times.
Old Dec 9, 2006 | 01:39 PM
gary c's Avatar
Wonderfull Nissan brakes.............
Take you car to the dealership and have it checked out.......better safe
than well you know. I have a '04 and my front pads only lasted 10K miles.
Those pads were splintering brake pad crud on my wheels and I knew I
had a problem. Have since switched to Hawk pads and I couldn't be
more pleased with the results!
Old Dec 20, 2006 | 03:08 PM
Zerk's Avatar
I've changed my brake pads 3 times in 3 years when I had the non-brembo setup on my 2003 5AT coupe. The 2003 5AT G35's had premature brake wear issues which is why they had a 3 year/36000 mile unlimited brake service. The pads would create so much brake dust I had to upgrade. The new brake pads in the later models aren't much better. That's why I swiched to the Brembo calipers and Hawk pads.
Old Dec 20, 2006 | 03:13 PM
DHCrocks's Avatar
my stock non-brembos lasted 30k in the front, the rears looked like like they could go another 30k.
Old Dec 28, 2006 | 11:55 PM
maj83's Avatar
lazy a$$
Are you using hawk pads with OEM rotors?
Old Dec 29, 2006 | 01:26 AM
StVincent's Avatar
i have an 04, and i need to make another trip to a dealer for squealing brakes at 25k. when my warranty is over, i'm getting Hawk brake pads also. i had them on my previous car, and they lasted a long time with minimal brake dust.
Old Dec 29, 2006 | 01:37 AM
dannyboi2088's Avatar
umm i have 25k miles on my brake pads and it starts to squeel sometimes so i have to change them soon......but i also did abuse my brake pads a lot from having to brake really hard when slow cars come out and just go extra slow in front of you and from peeling out my tires....lol
