View Poll Results: Did you put on Aftermarket Shock with the New Springs?
Yes
27.08%
No
72.92%
Voters: 48. You may not vote on this poll
*** POLL: How many of you put aftermarket shocks when you swapped springs? ***
Old Dec 15, 2006 | 09:46 AM
Slick 6MT's Avatar
Exclamation *** POLL: How many of you put aftermarket shocks when you swapped springs? ***
If you didn't put new shocks on when you swapped the springs please let me know if you've encountered any problems. (bouncy ride, blown shocks, etc.)
Thanks,
Anthony
Old Dec 15, 2006 | 10:20 AM
jimmykce1's Avatar
I used my OEM Sport shocks when I installed my OEM 350z spring/front and coupe springs/rear. However, the spring rates on the 350Z springs & Coupe springs matched my OEM sport springs on my sedan, but just lowered the car.
Old Dec 15, 2006 | 10:23 AM
Slick 6MT's Avatar
FYI: I plan on putting a set of Tein 350z H-Techs on and I was hoping to get some feedback from those who have experience with this setup.
Old Dec 15, 2006 | 11:25 AM
Zerk's Avatar
My coupe does not have the sport suspension and dropped my car w/ the Eibach Pro Kit and haven't encountered any problems. I got a 1" drop all around and the car rides tight. I plan on buying aftermarket shocks in the future.
Old Dec 15, 2006 | 12:54 PM
ttrank's Avatar
Grocery getter
I put H&R springs on my stock sport struts but am now changing to D-specs. There were no problems, just not happy with the performance.
Old Dec 15, 2006 | 12:57 PM
Slick 6MT's Avatar
Would you mind elaborating a bit on this?
Thanks
Old Dec 15, 2006 | 02:23 PM
Philly_G35's Avatar
I was lowered on Eibach Prokits with stock non-sport struts. The ride didn't seem to bad, but I came across a set of D-Specs for a good price so I jumped on them. I do remember the splash guards on my sedan would bottom out in hard corners before the D-specs.
Old Dec 15, 2006 | 02:48 PM
ttrank's Avatar
Grocery getter
Thanks
Sure, the oem sport struts are made to ideally work with the spring rate and height of the stock springs. They do work with aftermarket springs but the performance is not as good as it would be with better struts. I am changing to Tokico D-specs so I can adjust them for different driving conditions. I want to be able to have a softer valving for street driving and then make them harder for track days or mountain runs. The sport struts on my car now are just too soft for spirited driving.
privatecorye
Steering & Suspension
May 31, 2016 01:56 AM
Frostbite91
Aug 12, 2015 05:16 PM
si_driver
Aug 11, 2015 07:08 AM
mcneil_g35
Lighting
Aug 5, 2015 01:09 PM
Jadenkid22
Jul 14, 2015 12:33 AM
