My new 6 pot BBK....
Old Jan 26, 2007 | 04:28 PM
  #31
Nismo G's Avatar
Originally Posted by 636Racer
nice.
You should attend a trackday/time attack function and see how them hold up. I think that will make or break it.
+1, They look Great! I would like to see them in red. I would also like to know where to order a set!
-sean
Old Jan 27, 2007 | 11:58 AM
  #32
Nismo G's Avatar
You did just the fronts correct? Did they give you a price on the rear?
-sean
Old Jan 27, 2007 | 03:04 PM
  #33
j-velocity's Avatar
-sean
Yea I just got the fronts...
They didn't give me a price on the rear... at least I didn't ask...
Old Jan 27, 2007 | 04:27 PM
  #34
RBull's Avatar
Rated M
Originally Posted by j-velocity
Finally got them installed 2 days ago and got the pic...
Fitting seems pretty good...
No mod was needed...]
I am still breaking in on the pads and rotor...
The car stoppes much better already...
But i am loosing pressure on the brake padel...
The padel seems softer than stock... The mec. said it will get more firm after than pads and rotor break in....
I would have the brakes rebled. You should not be losing pressure. That is probably why they feel slightly soft. IMHO, it's doubful break in will make them feel much more firm. I had the same issue with my Brembos when i changed to stainless lines. I had to have them bled a second time and now they are perfect.
Nice brakes. Enjoy.
Old Feb 21, 2007 | 02:04 PM
  #35
mc2's Avatar
mc2
I agree with the previous guy.
Bleed the brakes, air in the system is pretty much the only culprit for soft pedal feel
Old Feb 22, 2007 | 02:19 PM
  #36
SeOuLG35's Avatar
wow..it looks great!
dropping+new rims will compliment your G
Old Feb 23, 2007 | 11:04 PM
  #37
BadBoy06's Avatar
those are crazy...nice find..were you get them from? $$$$
Old Mar 1, 2007 | 04:41 PM
  #38
ttrank's Avatar
Grocery getter
^+1
How about a GB? Can you hook us up with your source???
Old Oct 26, 2007 | 04:25 AM
  #39
Godzilla35's Avatar
very interesting... tell me they come in black or red too??? hook it up with your source....subscribing!!!!
Old Oct 26, 2007 | 05:27 AM
  #40
johnsonhuang's Avatar
if u only did the front bbk. wont your car look all funny since u have mis-matched brakes? and wont it affect your cars stopping ability since not the same amount of brake force is applie dto both F/R?
Old Oct 26, 2007 | 07:45 AM
  #41
G35fromPA's Avatar
Yes, any front-only BBK that has't been thoroughly tested to see if retains the stock brake bias can negatively affect stopping ability/lengthen braking distances. It may "feel" more powerful under initial braking, but that's because the fronts now grab harder for less pedal pressure (the bias has been thrown forward) but in reality you've reduced the line pressure to the rears as well, leaving them to do less work. This actually results in less powerful braking to all four wheels and can lengthen stopping distances.
Has this kit been tested and sized properly with the 06 brake MC and system?
Old Oct 27, 2007 | 05:49 AM
  #42
j-velocity's Avatar
I don't know if this kit has been tested and sized properly with the 06 brake MC and system.
But it brakes much better than the stock brakes.
AFAIK, rear brakes are mostly for assistance only because once you step on your brake the weight of your car are transfered to the front.
Old Oct 27, 2007 | 05:56 AM
  #43
j-velocity's Avatar
It comes in black, red, purple, blue, gold and green.
I may able to arrange a GB... Now I am waiting for my supplier to get me a price quote.
PM me if you are interested.
Old Oct 27, 2007 | 05:58 AM
  #44
j-velocity's Avatar
Originally Posted by ttrank
^+1
I can try to arrange a GB right.
but do i need to get a permission from the Mods?
Old Oct 27, 2007 | 06:29 AM
  #45
ttrank's Avatar
Grocery getter
You might. Find out a price first.
Also did you say that kit is a 355mm? It looks like a 332mm to me. Most of the 355's I've seen on oem 19's don't have much room.
