19inch m45 wheels on my g35x question
Old Jan 9, 2007 | 11:52 AM
redlude97's Avatar
You might not need spacers since you have a sedan, but even if you end up needing them, hubcentric spacers that use longer studs are perfectly fine to use, there are quite a few runnning them already
Old Jan 9, 2007 | 01:51 PM
az1anbeethoven's Avatar
+1 on hubcentric spacers...by the way, you would need a 5mm spacers in the front...
Old Jan 9, 2007 | 02:34 PM
dunglan7's Avatar
I have +5mm H&R spacers in the front and they are perfectly fine so far.
Old Jan 18, 2007 | 01:34 AM
BlueFalcon915's Avatar
If they are centered properly (hubcentric), then they will be fine. Spacers and adapters don't harm anything if the centerline of the wheel/tire remains the same. You just can't run TOO thick of a spacer because then your lug nuts don't have enough bolt to grab onto.
Old Jan 18, 2007 | 08:18 AM
seddon's Avatar
Try pming JOVO he has the M45 wheels on his 06X I believe he a spacer with longer studs.
Cajuncowboy
Jun 21, 2021 09:47 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
Mac8008
Aug 4, 2015 09:19 PM
kinetek
Aug 3, 2015 04:25 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
