from stock to Brembo Brake system?
Old Jan 25, 2007 | 11:16 PM
edindaclub's Avatar
i currently have the stock brake system, wut do u need besides the caliper to get the whole system set up? how much am i looking at ??
Old Jan 25, 2007 | 11:29 PM
JSpec350GT's Avatar
^^ I want to know this too.
T
Old Jan 25, 2007 | 11:37 PM
Derek173's Avatar
all you need is the rotors and calipers. I replaced my original brakes with 6mt brembos. .. you have the cut the shielding around the stock rotors otherwise Direct bolt on.
Unless you find a good deal on stock brembos consider a Stoptech big brake kit or any other brand. If you buy used brakes and the rotors are shot... now you have to buy rotors. I ended up getting new front rotors a year after i upgraded. Got stoptech 2piece fronts (great rotors) now if I add up new rotors + used brembos = New front bigbrake kit.
Old Jan 26, 2007 | 12:28 AM
JSpec350GT's Avatar
No brake lines needed? Stock ones can be used with Brembo?
T
Old Jan 26, 2007 | 01:29 PM
Derek173's Avatar
T
good point, mine came with a the brake line still connected so yes brakelines too. Maybe the stock will work
But if you are upgrading anyway..why not just get some aftermarket brake lines..cant go wrong
Old Jan 26, 2007 | 02:03 PM
dklau33's Avatar
The stock non-brembo lines will not work with the brembo calipers. You either need the oem brembo lines or something aftermarket. Also the bolts for the rear bremob caliper are different than the non-brembo ones so you'll need those as well.
Popes
Jul 29, 2015 05:07 PM
Karnicle
Jul 23, 2015 05:08 AM
vstypicals
Jul 20, 2015 10:55 PM
papo020
Jul 17, 2015 10:30 PM
