car lowered 2" with 255/35/20 in the front. problems?
Old Feb 20, 2007 | 08:33 PM
accordfreak's Avatar
Anybody have problems rubbing with 255/35/20 lowered 2" with an aggressive offset??? if you did, how did you solve the problem? I really don't want to raise it. I'm thinking the only option is to either run an aggressive camber or smaller size wall tires... sigh...
Old Feb 20, 2007 | 09:18 PM
Tarheel's G's Avatar
I have 20" 9.5 wide in front with 245/35/20. I lowered just over an inch and occasionally rub on bumps. I think 2" would give you trouble.
Old Feb 20, 2007 | 09:22 PM
redlude97's Avatar
Buy adjustable a-arms and crank up the camber until the rubbing goes away
Old Feb 21, 2007 | 12:20 AM
extreme4377's Avatar
Lexus IS350
Im running a 19" wheel with a +26 offset and 265/35/19's up front, no rubbing problems at all lowered about an inch on Tein 350Z H-tech springs.
Old Feb 21, 2007 | 12:27 AM
redlude97's Avatar
Your offset isn't aggressive and your drop isn't even over an inch so its hardly the same situation, not sure how this will help him out?
Old Feb 21, 2007 | 12:38 AM
Calvin's Avatar
Overglorified Altima
run an aggressive camber! i love the way it looks!
unfortunately, it isn't cheap
Old Feb 23, 2007 | 05:13 PM
BadBoy06's Avatar
2" drop OMG No wonder you rub with that size tire
Good luck on that 1
Old Feb 23, 2007 | 06:11 PM
redlude97's Avatar
You may have to remove your fenderwells also, its pretty common way to stop some rubbing on an extreme drop, and allow you to fully roll the front fenders for some extra clearance
Old Feb 24, 2007 | 10:36 AM
BadBoy06's Avatar
So get rid of them altogether (fenderwell)?
Old Feb 24, 2007 | 10:49 AM
Gilley's Avatar
One problem is that the 255/35/20's are about an inch larger in diameter than the OEM front tire diameter. It may even be larger in diameter than your rear tire. A 255/30/20 is really close to the OEM front tire diameter while 285/30/20 is about the same diameter as the OEM rear.
Old Feb 24, 2007 | 03:04 PM
redlude97's Avatar
Yes the plastic pieces inside the fenderwell can be removed. I don't really recommend it, but alot of honda/nissan guys do it to get some extreme drops. You can also apply rubberized undercoating on the exposed areas too, just be sure to mask the hot engine areas so they dont get coated
Old Feb 24, 2007 | 11:21 PM
BadBoy06's Avatar
man the **** people do to get a crazy drop..lol
good insight though
Old Feb 27, 2007 | 04:42 PM
richiesays's Avatar
2" drop is insane! I want to see the pictures! =)
chinee
Jun 10, 2024 07:48 PM
rezendvous420
May 31, 2020 01:26 PM
mike730
Jan 12, 2018 04:25 PM
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
newg37
Jul 26, 2015 09:32 AM
