Best lowering springs?
Old Feb 27, 2007 | 04:41 PM
richiesays's Avatar
I like my TEIN S-Techs. Especially after they settled, now they're almost perfect. I just wish my G was slammed but then I wouldn't be able to drive it anywhere.
Old Feb 27, 2007 | 11:13 PM
Concealed StrateG35's Avatar
Originally Posted by delion21
Do the right thing man. I went with H-Techs and I hate the drop in the rear. If you want it done right get teh camber kit and then you can get Tenabe or and Tein S-Techs. Then when you really got osme extra cash to blow go with Tein Coilover Basics.
I don't think I will need a camber kit with SWIFT, will I ?
Old Feb 27, 2007 | 11:53 PM
Andy2434's Avatar
Originally Posted by BadBoy06
Most folks (as I can tell) will eventually change/swap the H-Techs
for something else down the road.
Yup! I am switching to S-Techs or Coilovers.
Old Feb 28, 2007 | 01:52 AM
redlude97's Avatar
Are you planning on running 350z Swifts? Then yes, you will need camber kits, at least in the rear for sure, and in the front as well if you want to maximize tire life. The only springs you are going to be able to run without camber kits are 350z h-techs, which most people barely got back into specs, or OEM 350z springs. Both give minimal drops in the rear without a springmount mod though, so don't expect anything drastic unless you are willing to get camber kits
Old Feb 28, 2007 | 01:37 PM
No I'm planning to run G35 SWIFTs
Old Feb 28, 2007 | 02:34 PM
Calvin's Avatar
Overglorified Altima
g35 swift springs will drop you approximately -0.984f/-0.591r
as with ANY sort of drop (no matter how little/much), a camber kit will help maxamize how much you get out of your tires. with the swift springs, you should be able to get away with flipping your tires.
Old Feb 28, 2007 | 02:35 PM
Meaning getting an alignment??
Old Feb 28, 2007 | 05:23 PM
redlude97's Avatar
I wouldn't recommend g35 swifts AT ALL! They have very soft springrates, softer than stock 280F/314R, which will hurt your performance significantly. 350z Swifts are a better choice because they have higher springrates, but will be a bigger drop and definetly need camber kits. 350z H-techs will give you approximetely the same drop as the g35 swifts, and have better springrates
sales@czp
Suspension-Vendor
26
Nov 6, 2017 03:04 PM
alessandro
Oct 8, 2015 09:29 AM
EasySausage
Sep 24, 2015 01:06 PM
bigmike
Sep 17, 2015 01:58 PM
ChickenTendrs
Sep 16, 2015 01:10 PM
