Brembo Brake Pad Question
Old Mar 11, 2007 | 07:03 PM
mwarsh1's Avatar
I Recenly Installed My Brembo Oem Brakes On My 05 Coupe. I Bought The Oem Brembo Pad, I Ssee There Is A Little Metal Clip Attached To Two Of The Pads, Which Side Does That Clip Go On, The Front (where You Cna See It ) Or The Back?
Old Mar 11, 2007 | 08:09 PM
Memphis's Avatar
Have you pulled the old pads out of the Brembo calipers yet? I don't recall which side the clip went on....I just pulled my old pads out and noted which side had the clips and re-installed the fresh pad in its place. I know this doesn't answer your question but that is what I did.
Old Mar 11, 2007 | 10:06 PM
mwarsh1's Avatar
Good Try
Old Mar 11, 2007 | 11:02 PM
Memphis's Avatar
Well, since I provided info that was of no use to you....let me continue that trend and provide a link to a site that tells everything about changing pads in Brembo's and even has pics but is completely useless for your purposes because they don't say anything about the wear indicator tabs.
http://www.g-owners.com/article_read.asp?id=31
Old Mar 12, 2007 | 10:15 AM
Gilley's Avatar
The clip goes on the back side of the caliper.
miata007
Aug 17, 2015 04:36 PM
kinetek
Aug 3, 2015 04:25 PM
sahizzle110
Jul 29, 2015 11:36 AM
EnCr1pt3d
Jul 29, 2015 03:35 AM
Karnicle
Jul 23, 2015 05:08 AM
