Question on Camber..
Old Mar 16, 2007 | 07:37 PM
hji1945's Avatar
I'm thinking of getting Tein Basic / Spacer(15mm F / 20mm B) / Toyo T1R 245/35/19 F and 255/40/19 on Stock rims.. Now I'm thinking of just leaving the drop as how it comes from the tein factory.. Will I need camber for alignment?? Will I only need front?? The most drop I will have will be 1.0" all around.. I've been searching around but wasn't sure about certain things.. So.. Thanks..
Old Mar 16, 2007 | 07:44 PM
redlude97's Avatar
With 1" drop all around, you will probably only need rear camber kits, fronts aren't a must at that drop but you will probably notice a little more wear than normal
Old Mar 17, 2007 | 12:30 PM
hji1945's Avatar
Thanks..
Old Mar 17, 2007 | 12:58 PM
Calvin's Avatar
Overglorified Altima
in the long run, it will pay off to get both front/rear camber kits (imo). but if you dont plan on keeping the car very long, or dont drive often/hard, then a rear camber kit will suffice.
most people run the rear kit only b/c the front is kind of expensive. if you run jut a rear camber kit, just remember to flip your tires and you shouldn't experience too much of a problem.
Old Mar 17, 2007 | 05:02 PM
hji1945's Avatar
Maybe I should just spend little more money on the camber and buy the front one also.. Cause I drive my car a lot and hard.. I had my car for 7 months and have 17000 miles on em.. So.. Any kinds of camber kit will work right? Like Stillen, etc.. Any preferences?
Old Mar 18, 2007 | 09:34 PM
BlkonBlkG's Avatar
How much are camber kits?
Old Mar 18, 2007 | 09:44 PM
Calvin's Avatar
you can get the eibach rear kit, which is the same as the spc rear kit, for about 150. you can get the spc rear kit for about 200.
the spc fronts are about 400. cuscos are around 550 (i think). 350evos are 850.
Old Mar 19, 2007 | 01:26 AM
redlude97's Avatar
If you drive the car hard alot, you may want to just leave the front camber alone because increased negative camber helps alot for handling.
Old Mar 22, 2007 | 05:45 PM
hji1945's Avatar
Thanks guys.. And I know this is wrong forum to ask this but I know I already started thread so I gonna ask.. Is it ok to get 245/35/19 F and 255/40/19 on stock 19s?? I know people get 245/265 on their 19s.. Will 245/255 setup mess up the VDC?? And should I get 245/35 and 255/35 instead because I am trying to lower my car?? Or should I lower less in the back and get 255/40 tires?? Thanks..
Old Mar 22, 2007 | 05:47 PM
hji1945's Avatar
Oh I forgot.. I am thinking of getting 15mm/20mm spacer.. Will I have any rub with 255/40 tires??
Old Mar 22, 2007 | 10:49 PM
binder's Avatar
it won't mess up vdc...i don't know why people keep asking that.
bryanr
Drivetrain
Sep 30, 2015 06:31 AM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
migurus
Sep 5, 2015 09:39 PM
TheBay
Sep 3, 2015 03:27 PM
erich2780
Sep 3, 2015 03:23 PM
