My alignment spcs....
Old Mar 19, 2007 | 04:59 PM
jimmyc13's Avatar
Thanks for the info Gdup re: the specs!
Do you know if Firestone will install the z/coupe suspension I bought used?
Old Mar 19, 2007 | 05:02 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
no problem. They will install it, but they'll charge you and arm and a leg. They go by Mitchell Labor Guide book and it calls for over 4 hours of labor for the front and rear spring/strut installs (even though i can do it in an hour) and at $110/hr... you get the picture. You'd be better off taking it to a custom shop that will only charge you an hour or two for labor.
-GP-
Old Mar 20, 2007 | 07:21 AM
jimmyc13's Avatar
-GP-
Wow...F-that! Sounds like they go by stealership theory....they quoted me 6 hrs total! Forgot to mention, I'm also going to have the SPC front camber kit installed too. I'll just go to my local guy I usually deal with then.
Thanks.
Old Mar 20, 2007 | 09:32 AM
SFG356MT's Avatar
Does anyone know how low is too low to get your sedan on the rack for an alignment? Does all the firestone shops use the same type of racks and machines to do the alignments?
Old Mar 20, 2007 | 09:36 AM
MardiGrasMax's Avatar
You guys that did the Z spring swap, did you put the stock rear shock back on or did you use the Z rear shock?
Old Mar 20, 2007 | 11:10 AM
accordhybrd's Avatar
I used all of my G shocks and Z springs
Old Mar 26, 2007 | 11:31 AM
jimmyc13's Avatar
Question Coupe suspension/Z-spring install issues.....
I posted up in this thread, since I didn't want to make a whole new one....as there seems to have been a lot of threads on lowering lately.
I had my coupe full suspension installed over the weekend, with SPC front camber kit. I went with the z-springs up front & the coupe springs in the rear. During the installation, the shop encountered issues with getting one of my rear shocks off. They indicated that a portion of the long threaded bolt was corroded & they were not able to free it…they even tried using a vibratory impact wrench & it didn’t come loose. They had the option to heat it up to get it off, but warned me that doing so could damage the bearings or bushings (I forget which one) and if they were damaged, the cost to replace would be $500….so I opted to not go that route. So they had to keep my sedan non-sport shocks in the rear & installed the coupe springs, lowering the car the ½” as others have done.
I’m aware that I had to replace the shocks & struts because of lowering the car and in order to avoid premature wear & tear on the shocks/struts, but because the drop is only 1/2” in the rear, is this less of a concern for me, being on the non-sports shocks? I’m thinking I’m better off (as opposed to having installed the z-springs in the rear and dropping it a full 1”).
Just looking for some feedback as to how long you think the rear shocks will be good for. I realize it is what it is and I’ll eventually find out, but just curious if I’m talking a year down the road…or a few months. Please let me know your thoughts.
Thanks!
On a separate note, the SPC front camber kit they tell me is quite the kit & had great adjustability, but it required them to have to move the ABS sensors on the car & some other modifications (some piece provided would not fit perfectly, so they had to modify it). Without relocating the ABS sensors, they said they drove the car down the road & the ABS kicked in while they were driving & the car was shaking/fighting back. Just an FYI to others who are installing this….I did have them install the spacer plates provided, as recommended by SPC…so not sure if leaving these out will avoid this issue or not.
Old Mar 28, 2007 | 05:50 PM
beatle9999's Avatar
I'm getting cusco front arms installed on my G in two days, the guys at the shop said he would charge me 65 bucks. I have a lifetime alignment at Firestone as well. Will I mess up my car if I get my cusco arms installed and drive like a mile to the firestone??
Old Mar 29, 2007 | 01:14 PM
jimmyc13's Avatar
I don't think you'll mess up your car, though will Firestone TRULY give you a free alignment, knowing you put a front camber kit on? I'd be shocked if they did! Good luck!
Old May 1, 2007 | 03:40 PM
Lucino's Avatar
so did your alignment change at all after the install?
Dallsinghjr1
Sep 17, 2023 11:25 AM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
MThawkins86
Oct 24, 2015 02:07 AM
Benja455
NorthWest
Sep 23, 2015 01:10 PM
migurus
Sep 5, 2015 09:39 PM
