Has anyone come across this strut bar before?
Old Mar 30, 2007 | 10:43 AM
  #181
g35man04's Avatar
CLUB MODERATOR
anyone find out if you can fit this with a 1/2 spacer?
Old Mar 30, 2007 | 12:59 PM
  #182
LjN_728's Avatar
Installed the bar yesterday. It rubs against the oem engine cover. Don't know if I'm just the unlucky customer or what. But in any case, noticeable difference taking this particular transition ramp before and after the bar install. She feels really sturdy going 60mph on a 80 degree turn. Good stuff!
Old Mar 30, 2007 | 05:20 PM
  #183
JJKK's Avatar
hum........ does anyone have the same problem??
Old Apr 2, 2007 | 09:38 PM
  #184
G35JAMMER's Avatar
Recieved strut bar today. Already installed. My car is an 03 coupe with a 5/16 spacer, z-tube, and stillen ca. The bar fits without the engine cover. Barely clears the top of the engine(1/16 at the most). Had to remove AC bracket, used rubber sleeve to protect line. Had no hood clearence problems. This bar is very light weight but appears to be fairly stiff I haven't driven the car yet but I expect to feel it's there.
Old Apr 3, 2007 | 01:53 AM
  #185
rockd's Avatar
ok, so it's confirmed - the bar WILL fit with a 5/16 spacer, but only if the engine cover is off (i don't mind...)
thanks, g35jammer!
Old Apr 3, 2007 | 04:46 PM
  #186
g20hybrid's Avatar
Does anyone know if it'll clear coilover dampning adjustments???
Old Apr 3, 2007 | 05:40 PM
  #187
dklau33's Avatar
Depends on which company and model. I think someone confirmed this fits with the Tein CS.
Old Apr 13, 2007 | 04:00 PM
  #188
filanj's Avatar
ANYONE ELSE'S BAR NOT FIT!!!! I CAN"T GET THIS DAMN THING TO BOLT DOWN FOR THE LIFE OF ME... just spend 2 hours trying to get it to work, but NO way... It's not a clearance issue... it's a construction problem
Old Apr 13, 2007 | 05:34 PM
  #189
accordfreak's Avatar
did u put bar the right way? R for right? L for left?
Old Apr 13, 2007 | 06:01 PM
  #190
filanj's Avatar
Yes Sir, I even tried to put it on backwards for the hell of it... but that wouldn't even sit on there. The last side of the triangle of the left doesn't sit low enough to get the nut threads locked. The only thing I accomplished was stripping the very tips of the bolts
Looks like the Richie SB FTMFW still
Old Apr 13, 2007 | 06:31 PM
  #191
erdog's Avatar
Did they send you one for the Z instead?
Old Apr 13, 2007 | 06:45 PM
  #192
filanj's Avatar
nope, it would be two leveled if it were for a Z
Old Apr 13, 2007 | 07:21 PM
  #193
so... none of the bolts screw in? if at least one screw in, screw it down tight. The strut bar base should be pressed down so the other nuts could be screwed in. any pics?
Old Apr 14, 2007 | 02:07 AM
  #194
NoLimit's Avatar
Originally Posted by filanj
/\ all of the nuts will go on except the LAST nut that needs to go on. it will not flex down low enough to allow me to get the nut started. i've tried just about everything i could think of to allow that side to be the lowest and it still isn't low enough to allow me to thread. i didn't take pictures. no other problems other than the last one having to go in...all the others went on fine and would bolt down all the way
posted this on the other thread too, but:
Is your car off the ground?? It should be when installing any FSTB.
Old Apr 14, 2007 | 07:54 PM
  #195
dklau33's Avatar
Why's that? I didn't have any problems installing my ARC bar with my car on the ground.
