Has anyone come across this strut bar before?
Old Mar 21, 2007 | 01:03 PM
  #106
sliderg35's Avatar
+1 - Installation of adjustable shocks is a pretty common modification that the design of the bar does not allow for. I think the Richie bar would still work for me because I have EDFC, but I think a minor adjustment to the design of the bar would allow of manual adjustment as well.
Old Mar 21, 2007 | 01:49 PM
  #107
blksnake's Avatar
subscribed
Old Mar 21, 2007 | 01:57 PM
  #108
Jeff92se's Avatar
Red Card Crew
Circuit Racing bar:
Richie bar on sedan.
Look at the thick mounts. If you have a sedan, you are going to have a hard time with this one.
Old Mar 21, 2007 | 04:12 PM
  #110
bull3t's Avatar
I just read a pm bob sent me and from what he told me I think this bar performs similar to richie's bar...I was gonna switch over to the circuit bar because i
thought the one piece design would drastically improve rigidity...but again from what he told me it sounds like he got similar gains to what the richie bar
offers...I think I'm gonna stick with my richie bar...
Old Mar 21, 2007 | 04:37 PM
  #111
05Scoobyroo's Avatar
If the A/C line bracket on the sedan is like the coupe, there is no way in the world you will be able to keep the A/C bracket on either car, and being that the Circuit Sports mounts are thicker, it may impact your ABS hardline as well. I would be curious to find out if this bar is hollow or solid, and also how any one with a coilover setup could utilize this, unless there is a deep "cone" cut out, or the bar is completely hollow at the mounting points. Heck, even if you have an EDFC or TEAS you would be SOL.
Old Mar 21, 2007 | 05:47 PM
  #112
bobshuai's Avatar
pictures and review
I think this is what everyone is waiting for.
This is my ride.
This is the right side view without the ac bracket. As you can see the black coupler is protecting it between the bar and the ac line plus holding it in its position. Too me I don't need the bracket because I realized what that bracket does and I am using this bar to do its job. But somone people don't want to loose any parts therefore is your decision to make.
Left side veiw, it pretty much clear everything from the left side.
This is left side angle view, you can see how close the bar is to the cover. Pretty much touching the infiniti sign.
This is another view from the front.
This one is the overall shot.
Newest update, after I took off my engine cover and I discover this.
I think this bar will clear 5/16" spacer and may be pushing the 5/8" spacer.
As far as the ride, I felt the difference under the high speed lane changing and handles a bit better on the 45 degree on ramp turn between freeway to freeway. I also noice that is less harsh when I go over the uneven road during the 40 to 60 mph drive. Beside that everything else is the same. Oh one more thing, the bar clears my carbon fiber hood but I don't know how to take a picture to show the prove.
As far as the DIY and tools. Here is the list of tools. Due to the tight space for reaching the nuts therefore I choosed these tools to do the job.
1/4" ratchet, 1/4" extension bar, 1/4" 10mm & 12mm socket, reducer adaptor from 3/8" F drive reduce to 1/4" M and 3/8" torque wrench. You can use different tools if you cant have the same tools. I sell tools therefore I have eveything. Don't forget to torq the nuts to 28ft/lb. ( I torqued them little by little)
DIY, just need to loose the ac bracket first then loose the nuts and put the bar either left or right first. But I went with left side first. I hope this will help.
Old Mar 21, 2007 | 05:48 PM
  #113
Calvin's Avatar
Overglorified Altima
thanks, bob! i know a lot of people have been waiting for these.
so have you taken it for a spin yet?
Old Mar 21, 2007 | 05:50 PM
  #114
SFLG35's Avatar
FGC President
exactly what i was thinking
now need some pics of it over a crawford or without the cover on
Old Mar 21, 2007 | 06:06 PM
  #115
binar's Avatar
Does that look like 5/16" to anyone... ?? anyone...??
Old Mar 21, 2007 | 06:10 PM
  #116
Calvin's Avatar
FYI:
Originally Posted by Phase 2
CS bar will fit both G35 coupe and Sedan, but we confirmed with Circuit Sports that it will not have enough room to clear plenum spacers because the underhood clearance between the hood and plenum is too tight. Even putting on spacers might clear the plenum but in return rubbing the underhood.
the bar will not clear the 5/16" spacer, maybe have to make a version to make the bar thinner. Even the clearance for the underhood is already very tight!
IMO, this was a HUGE mistake on CS's part. not fitting over plenum mods will greatly sacrafice a lot of sales, IMO.
Old Mar 21, 2007 | 06:20 PM
  #117
binar's Avatar
Thanks Hero.. ummm where was that information posted? 350Z? I was only following this thread.
Old Mar 21, 2007 | 06:21 PM
  #118
Calvin's Avatar
yes, on the my350z thread.
post #43 and #44
http://www.my350z.com/forum/showthre...=256795&page=3
Old Mar 21, 2007 | 06:31 PM
  #119
bustemupbob's Avatar
Hey Bob,
Is there enough space for an coilover setup under those mounting points?
Old Mar 21, 2007 | 06:32 PM
  #120
Skaterbasist's Avatar
Retired SuperMod
Thanks for the info.
Your right, it's a huge mistake that will make it lose customers like me.
I have a 5/16 spacer on order, so I guess its Richie for me.
