Help With Megan Coilovers
Old Mar 24, 2007 | 12:36 AM
bustemupbob's Avatar
Hello All,
Question?
I installed my Megan Coilover set-up on my car, No Instructions Included with them.
So here is the problem, my car is to damn low.
On a megan coilover can the lower spanner be adjusted? Or just the top two spanner nuts?
are the Boxes in red adjustable?
This is what too low looks like.
Old Mar 24, 2007 | 01:05 AM
Gam3's Avatar
that is really low...makes the oem 17s look not half bad lol...even tho there hideous
Old Mar 24, 2007 | 04:34 AM
PEtaG35's Avatar
Wow thats low! lol
Old Mar 24, 2007 | 04:32 PM
Bump: Anyone Need Help Thanks
Old Mar 24, 2007 | 05:01 PM
aleok's Avatar
yes, you use the "lower spanner" to adjust the height, just turn the thing to the left.
Old Mar 25, 2007 | 03:49 PM
5150DS's Avatar
bustemupbob, let me know how high you are able to get your car after adjusting. I am thinking about these coil overs for my sedan but with same front and rear rate springs. I am just leary of them being too low like Tein. Do they have adjustable pillow mounts?
Old Mar 25, 2007 | 03:54 PM
Gsedan35's Avatar
They will bring a sedan up to a 350Z drop or 1" with the recommended minimum amount of spring preload dialed in. If one wanted to add in some additional spring preload and possibly adding in a spacer above the rear height adjustment system you should be able to get a addtional 1/4"-1/3" of height.
Old Mar 25, 2007 | 04:33 PM
5150DS's Avatar
Thanks Gsedan35, as always you are very helpful.
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
Picture Share
Feb 4, 2018 12:41 PM
9tray turbo
Sep 29, 2015 10:22 PM
