Added some 25mm spacers and rolled my fenders on saturday and ended up with flushed wheels. Probably coulda gone another 5mm but didn't want to push it.
I think the picture is a little deceptive because the ground is slanting, the camber it at -1.5 which is inside of factory specs, adjusted with spc camber arms
looks awesome.
i guess the tire is very flush with the wheel?
which spacers did you go with? also, how was the threading of the studs when adding on the lug nuts?
The rears look great. I was considering a slight bump at the rear. I may have to look into this.
Actuall, I have two questions. First how did you roll your fenders, second I've been looking at new wheels do you know if 19" by 10.5 wide will fit the coupe?
Copyguy
Copyguy
Quote:
-1.5 with 0.05 toe? thats about as spot on as you can get. Notice the pic is kinda angled to give the illusion of extra camber Originally Posted by ttrank
Wow those 285's are not going to last long with that kind of camber!
Heres a more accurate representation of the camber.
Real nice redlude.Originally Posted by redlude97
Are those 19'' or 20" rims?
