Using 04-05 Coupe Specs w/18" wheel
Specified Range for Front Camber: -1.3|0.3
Specified Range for Front Toe: 0.00|0.08
Specified Range for Rear Camber: -1.8|-0.8
Specified Range for Rear Toe: 0.00|0.22
Front: Left
Camber: -1.2
Toe: 0.02
Front: Right
Camber: -1.5
Toe: 0.05
Rear: Left
Camber: -1.5
Toe: 0.10
Rear: Right
Camber: -1.5
Toe: 0.18
Front
Cross Camber: 0.3
Specified Range: -0.8|0.8
Total Toe: 0.07
Specified Range: 0.00|0.18
Rear
Total Toe: 0.29
Specified Range: 0.00|0.44
Extremely happy with the outcome considering the front is dropped approx 1.5" and rear 1.3"(with added spacer).
looks good, the only problem I see is with the rear toe being so off from each other. Try and bump the rear right toe down to .1 if possible at the camber, or kick the camber down to -1.6 and then adjust the toe so they are even on both sides
