Question...Wheel Width Vs Tire Width
Old Apr 5, 2007 | 01:40 PM
G35 Drummer's Avatar
Can i put 235/35/19 on all 4 wheels (stock 05 rims)
i believe the rear is 8.5"wide
correct me if i'm wrong.
Old Apr 5, 2007 | 02:25 PM
redlude97's Avatar
they'll fit, but the question is why you would want to run such a size all around?
Old Apr 5, 2007 | 02:41 PM
Because i have this 4 - 235/35/19 set just sitting in my garage so instead of spending $1200 on new ones i'd just use the ones i have until they're done then spend the $1200.
How would it affect my performance if any in terms of handling, acceleration, and going 100+
Old Apr 5, 2007 | 02:45 PM
redlude97's Avatar
Your handling will likely suffer because you decreased the width in the rear, you'll increase your chances of bending/cracking your wheels because the tires are too small, and you'll hurt your top speed because the tires are too short. Sell those tires and get the correct ones, you own a G, don't cheap out
Old Apr 5, 2007 | 02:55 PM
I hear ya bro but i'm broke, so i may have to settle for this for now.
Old Apr 5, 2007 | 02:56 PM
Jeff92se's Avatar
Red Card Crew
I'm a sedan guy running the coupe 19s. I was going to try to run this size when it came to swapping tires. Size-wise they fall into the acceptable ranges for both the 8" and 8.5" wheel. But as redlude said, you will be thinner in the rear by 10mm and you will have less rim protection. Personally, if you can feel a 10mm diff in tire width, you probably are a much better driver than any of us. Plus IMHO the tire brand/model would make more of a diff in grip than the size (at least in this case where the size diff is so small)
If you sold your current set of tires, how much? And what brand/model are they?
Old Apr 5, 2007 | 03:07 PM
well these tires are Toyo Proxes 4
Old Apr 5, 2007 | 04:29 PM
erdog's Avatar
Can't you just buy some new tires for the rears? Or is that too much $$$ too?
TwinTurboZ
19 Inch
Sep 26, 2015 06:11 PM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
bananax
Wheels & Tires CDN
Sep 10, 2015 06:14 PM
philthethrilloh
Sep 9, 2015 01:25 AM
socaldavid
Sep 5, 2015 04:35 AM
