Issues bleeding my brakes
Old Apr 7, 2007 | 08:23 PM
maicoJr's Avatar
I am having some issues with my brakes. Yesterday i installed four new EBC dimpled and slotted Rotors and Greenstuff EBC pads. We loosened the front brake lines to be able to remove the rotors and pads. We did not loosen the the rear brake lines. We did bleed the brakes without disconnecting the battery but no air bubbles came out of the lines. So, when i tried braking, my were not working until i pumped the brake 2 to 3 times, hence i have air in the line.
So, we disconnected the battery and bleed the brakes and i was able to get my brakes to brake a little bit but the brake was way to soft. We bleed the brakes five to six more times and each time the brake got a little better but still very soft. Do i need to continue bleeding the brakes or is there something wrong with the ABS system or should i at this point take the car to the dealer and have them bleed the system and pay $139. What should i do?
Old Apr 8, 2007 | 08:38 AM
silvernole12's Avatar
tap your calipers with a rubber mallet. That could loosen up any trapped air bubbles.
Old Apr 8, 2007 | 03:26 PM
n1cK's Avatar
G35 6MT
Thumbs up try this...
make sure you are bleeding BOTH bleeders on EACH caliper. do the outside first, then the inside. the bleeding order is right-rear, front-left, rear-left, front-right. make sure your car is level.
also, during the bleeding process, make sure the filler cap is on tight. only open it when you need to fill again (DO NOT let the level get below the MIN line). repeat the process 5-10 PER WHEEL.
this procedure from Stoptech may help. don't pay attention to their bleeding order. the order that i said is straight out of the FSM.
SiMpLyMoDiFiEd
The FX-Spot
Dec 2, 2021 04:35 PM
Terry_G35
May 9, 2020 01:39 AM
derres
Aug 28, 2015 03:27 PM
itschuckster
Jul 25, 2015 08:07 AM
Lsantana757
Jul 20, 2015 09:08 AM
