help with front camber kit
ive finally made my choice in what springs im going to kit. im going to run with swift 350 springs. ive already got spc rear camber kits now i just need the front arms. i was going with spc fronts but with the issues people are having im second guessing them. ive looked at stillen and 350 evos but there kind of pricey. ive also looked at cusco but read that there not a good choice. are there any other kits out there i should look at? ive read i dont really need one but id like to play it safe.
thanks
thanks
Does the drop from the springs but the front camber out of spec? I dropped my sedan around 1.5" and the only thing out of spec was the front right camber @ -1.5, maximum spec was -1.3.
Being at the edge of the spec isn't exactly ideal, and if you really want camber arms then it will help with tire wear. I recommend the SPC arms since your drop is relatively conservative, people have only been having problems with closer to 2" drop. Another option is the SPL camber arms which I like alot based on their rep on my350z.com
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
