which is better suspension overall?
Old Apr 9, 2007 | 11:48 PM
g35ivp's Avatar
between the eibach prokit and tein S-techs for the 03-06 coupes overall as in comfort, aggresive stance, etc. ?
Old Apr 10, 2007 | 12:27 AM
redlude97's Avatar
comfort and stance goes to the eibachs as they are lower and progressive. The 350z s-techs take it for performance though
Old Apr 10, 2007 | 12:29 AM
Calvin's Avatar
Overglorified Altima
the only downside to eibachs, from what ive read...not from personal experience, is that they sag more and more over time.
Old Apr 10, 2007 | 12:36 AM
redlude97's Avatar
I never recommended them and I personally would never use them, I just answered their question. I've heard about the sagging issue also, but I think thats the case in general for soft progressive springs
Old Apr 10, 2007 | 12:38 AM
ttrank's Avatar
Grocery getter
It depends on what you want. Ride or performance?
Old Apr 10, 2007 | 12:41 AM
Andy2434's Avatar
I have seen both the eibach prokit and 350Z S-Tech (drops lower and has a higher spring rate than the G S-Tech) set-ups. They both looking excellent and afford an excellent drop. They will both lower a Coupe some 1" to 1-1/4". Both will require camber kit(s), due to the increased negative camber. They will potentially promote premature tire wear, if that is a concern. I would personally go with the Z S-Techs.
I do not have info on the eibach prokit. The Z S-Tech has a spring of 386f/403r, which should offer a good ride depending on what you are riding on at the present time. To give a comparison, the Tein Basic spring rates are 504f/504r . . . And they are quite comfortable in themselves.
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Patrick Bovee
Oct 1, 2015 10:42 AM
