Does anyone know the location of the reciever or receivers(more than one) for the TPMS sensors in the wheels? Is there just one that picks up the signals or individual recievers in each wheelwell? I have an idea for a new way to deal with the TPMS sensors if the range on them is great enough.
Quote:
Is this info in the service manual? Why is keeping the location of the tpms sensors important relative to wheel position then? I hope someone can answer this, as I think we can make a PVC tube with capped ends, throw the tps sensors inside, install a valve stem in the side, and inflate to 32psi and it will trick the sensors and turn the light off without the need to band the tpms sensors in the wheelsOriginally Posted by helldorado
There's only one. Its the same unit that receives the signal for your key fob.
Quote:
someone has been putting thought into this. Originally Posted by redlude97
maybe kpierson has some input...
Quote:
Nope, made it up.Originally Posted by redlude97
Yes its in the FSM.The physical position is meaningless. Its all about how they're registered with the BCM so you can get an accurate indicator of which sensor is having an issue. If you were actually using them in your wheels, you'd want to register the FR sensor in the FR position and so on. So if that sensor had failure, the warning indicator would accurately reflect that and not another position.
Banding the sensors in the wheels isn't to just turn off the light. Its so you can actually use the TPMS system on wheels where the sensor wouldn't fit in the wheel's standard valve stem position. If all you want to do is turn off the light, then just throw them in a pressurized container. Where its located on the car is meaningless as long as the the signal is readable.
Quote:
The spare is at ~60psiOriginally Posted by maj83
how about putting the tpms in the spare tire?
Quote:
Yes its in the FSM.
I just wanted to see if this worked, I plan on banding my sensors when I flip the tires on my rims. I was just thinking about it and thought something like this might work, and you could just stick the tube in the trunk for something. Alot of people don't install their because they don't have bands, and this would be an easy fixOriginally Posted by helldorado
Nope, made it up.
Quote:
Assuming it would even fit, would you keep 4 spare tires? Originally Posted by maj83
Quote:
with how much (or how little in your case), when do you plan on flipping the tires? i wouldn't think any time soon, right?Originally Posted by redlude97
Quote:
My fronts had some camber wear on the front tires because I bought them used, so the inside tread is ~50% while the rest is ~80%, so I want to flip them so they'll last longerOriginally Posted by aHero4Eternity
Quote:
ah, okay. i was under the impression that everything was new. and i remember you saying you drive seldomly. hence i was surprised that you are flipping them soon.Originally Posted by redlude97
makes sense.
