is there any negatives about using spacers??
im thinking 15mm front and 20mm rear on stock 19's(i have tein s-techs)...i dont know to much about them so i was just wondering if theres anything else i should know or what to look out for???...thanks
Spacers will increase the wear on your wheel bearings in theory, but as long as they are hubcentric and come with either longer studs or bolt over existing studs you should be fine
ajusa.com, make sure you get the ones that bolt over the stock studs by checking on eibach's application list on their websit
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
FreshVQ
Sep 30, 2015 01:41 PM
