G coupe question
Old Apr 22, 2007 | 09:40 PM
sahiwal007's Avatar
G coupe question
hey guys
quick question: i just recently recived my 07 G coupe with the 19'' rims and sports tuned package and the question was if my coupe was already lowered by the sprts package? or is it just me?
thanks all
Old Apr 22, 2007 | 10:53 PM
BadBoy06's Avatar
just looks that way because of the side skirts
you will see a nice gap above tires
Old Apr 23, 2007 | 11:43 AM
ISMSOLUTIONS's Avatar
No factory lowering done...bigger wheels and aesthetics, tighter suspension...Rick
Old Apr 23, 2007 | 02:57 PM
jcv423's Avatar
it's just you
Old Apr 23, 2007 | 04:41 PM
sahiwal007's Avatar
thanx what springs should i lower my stock 19's with? i dont want no rubbing but yet i want the ride to be low
Old Apr 23, 2007 | 06:19 PM
StreetChase's Avatar
You can either go with Tein H-techs which are a less subtle drop or the Tein S-techs which are a little bit more of an aggressive drop. Or you can go the coilover route and go with numerous different things. Its all up to you and how much money you want to spend. Search it
Old Apr 23, 2007 | 09:28 PM
sahiwal007's Avatar
oh ok, im thinking for a more aggressive drop ill prob go with the Tein S-techs springs , but will i have rubbing issues, with my stock 19''s?
Old Apr 23, 2007 | 09:33 PM
You shouldn't rub at all...but you will go through your factory shocks pretty quickly...get the best of both worlds and get the Basics coilovers...you can at least adjust the height to whatever you want, instead of whatever the springs give you once they settle. Also, you'll need camber kits front and back...SPC makes a great combination that's affordable and great quality.
Rick
Old Apr 28, 2007 | 07:50 PM
sahiwal007's Avatar
im still thinking of what to go with? i need a drop bad!
Old Apr 28, 2007 | 08:14 PM
gary c's Avatar
Lowering......bottom line!
If you want an agressive drop then you should go with coilovers, much better
than just springs. If on the other hand you just want to close that gap over
the top of your tires (1 inch) then I'd opt for the Tein 350Z H Techs.........
our sponsor everythingg35.com normally has those available in stock for a
great price.........good luck!
Old Apr 29, 2007 | 01:01 PM
sahiwal007's Avatar
so if i get coilovers do i still need chamber kit?
Nicksims13
Oct 15, 2015 01:57 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
kd03g99
Jul 30, 2015 11:24 AM
mushu
Jul 15, 2015 03:55 PM
