Coilover, sway bar and rear camber kit installation
Old Apr 22, 2007 | 11:27 PM
dkl14's Avatar
Coilovers, sway bars and rear camber kit installation
I was quoted $500 plus tax to install Tein Basic coilovers, Hotchkis sway bars and the SPC rear camber kit. Is this reasonable or does it sounds little steep? Thanks.
Old Apr 22, 2007 | 11:33 PM
Cost a G's Avatar
Honestly...I think it can be cheaper..
Old Apr 22, 2007 | 11:38 PM
Andy2434's Avatar
Hmmmm . . . Let's see . . . Approximately some 2 hours to install the Tein Basic itself with a road test thrown in, some additional height adjustments, if so desired/required . . . Better make that 2-1/2 to 3 hours to assure that it's done properly. They're going to charge to at least a whole hour to install the sway bars. Figure another 1 hour to install the SPC set-up. I am assuming that you will be installing the toe bolt, as well. Including taxes, at $90.00/hour shop rate . . . That sounds about right. Please be reminded that you will need an alignment as well.
Old Apr 22, 2007 | 11:39 PM
Andy2434's Avatar
It can . . . But it will not be, unfortunately.
Old Apr 22, 2007 | 11:45 PM
dkl14's Avatar
Thanks Andy. I'll probably be taking advantage of the Firestone lifetime alignment. When do you recommend getting an alignment? Should I allow the coilovers to settle for a couple weeks?
Old Apr 23, 2007 | 12:14 AM
Andy2434's Avatar
Based on what you are installing, I would get an alignment after everything is installed . . . Considering that your G will have a much lower stance, after the Tein Basic install, and that the install of the new camber arms will throw your existing camber waaay out, even if they adjust the new arms to the same length as the old ones . . . The new camber will be way off. I would have an alignment done right away to be on the safe side.
rezendvous420
May 31, 2020 01:26 PM
atk08
Jul 30, 2015 03:12 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
nascarbuff17
Jul 16, 2015 10:23 AM
