Tein Basic question
Old Apr 24, 2007 | 08:34 PM
engs12's Avatar
Tein Basic question
I just got tein basics installed on my car. I did a mild drop of an inch all around. Waiting for my camber kit to come in before I drop it any lower. My question is does ride height determine better handling? To be clearer, would a 1.5in drop have better handling than a 1in. drop?
Old Apr 24, 2007 | 08:42 PM
izmir41500's Avatar
G35driver Addict
yes and no. lowering lowers the center of gravity so there is more balance and less weight transfer. handling depends on the whole suspension, ie spring rates, dampers, etc. but all things equal, lower is better, up to a point.
Old Apr 24, 2007 | 08:48 PM
engs12's Avatar
I'm loving the way it handles...best mod I've gotten so far. I might just leave it at the current drop. Also, I've read that springs do need a bit of time to settle for a drop. Is this the same for coilovers?
Old May 3, 2007 | 07:40 PM
redlude97's Avatar
For the case of the basics, lowering also can improve handling, because the method that the coilover employs for lowering the car in the front is to compress the springs, increasing the preload and essentially increase the "springrate". This results in a stiffer suspension which can increase performance along with the lower center of gravity
Old May 3, 2007 | 08:56 PM
ttrank's Avatar
Grocery getter
^ what he said.
Old May 3, 2007 | 09:08 PM
engs12's Avatar
So is it better with it being lower in the front?
Old May 4, 2007 | 04:52 PM
spooze's Avatar
are you completly happy with your tein basics. im thinking about order tein basic with spc camber kit
Old May 4, 2007 | 04:54 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
i have the same setup and couldnt be more happy.
-GP-
Old May 7, 2007 | 03:33 PM
G-MENTED's Avatar
besides the tein basics and/or a camber kit... any other parts you would recommend?
Old May 7, 2007 | 03:37 PM
If you want a full suspension upgrade then i'd add some sway bars into the mix.
-GP-
Old May 7, 2007 | 08:30 PM
Andy2434's Avatar
-GP-
Yes, sway bars should definitely be in the equation.
Old May 29, 2007 | 07:01 AM
imtheprez's Avatar
thinking about ordering tein basic coilovers, spc camber kit, and maybe sways...anything else? need new springs?
Old May 29, 2007 | 10:32 AM
superdds's Avatar
coilovers already have springs integrated...no need for them.
Old May 29, 2007 | 04:38 PM
imtheprez's Avatar
[QUOTE=superdds]coilovers already already have springs integrated...no need for them.[/QUOTE
thanks..figured that just wasnt too sure..never upgraded suspernsion before
Old May 30, 2007 | 04:41 PM
MyLilBlkG's Avatar
do you really need a camber kit for a mild 1 inch drop?
