350Z combo vs Sedan sport suspension combo
Old Apr 25, 2007 | 03:50 AM
bbboltz's Avatar
whats the diffrence between Z spring/shock combo vs the sport suspension sedan spring/shock combo installed on base 2003 SEDAN.
I know z spring drops about 1" on sedan and coupe spring drops .5"... but how about sport suspension?
I did a search but it didnt give me clear answer on diffrence between z combo vs sport suspension combo to sedan, only on z combo vs coup combo. TYVM
Old Apr 25, 2007 | 04:08 AM
redlude97's Avatar
sedan sport combo has same springrates as the unrevised Z setup, but without any drop at all.
Old Apr 25, 2007 | 04:15 AM
bbboltz's Avatar
why put sport suspension shock with unrevised z spring when u can get revised z combo and save hassle???
(sorry abot n00b question but no one answered it clearly...)
Old Apr 25, 2007 | 04:31 AM
perry05G35's Avatar
It really doesn't matter depends on what's available if you can find revised springs and shocks then go for them if you can't and all that is available is the unrevised springs or G35 coupe rear springs then you can use those. The key is to make sure you pair the right springs with the right shocks. Does that answer your question?
Old Apr 25, 2007 | 04:33 AM
bbboltz's Avatar
got ya TYVM
Old Apr 25, 2007 | 02:37 PM
dklau33's Avatar
The Z rear shock is about 1/2" shorter IIRC compared to a G rear shock. Also they are valved differently.
Old Apr 25, 2007 | 03:16 PM
jameyb's Avatar
Revised Z springs have a higher rear spring rate than the sedan sports suspension. As a result, if you go with a revised setup the ride will be more stiff but may handle better. The decision is a trade-off, it is up to the individual owner. Plus, a combo will be more expensive than just buying springs.
The thing you do not want to do is go with unrevised Z shocks. They are the reason the suspension was "revised" to begin with. They reportedly had a big problem with bounciness.
Old Apr 29, 2007 | 09:32 PM
Max626's Avatar
so Z revised springs upfront and coupe in the rear correct? If so we still have no shocks out yet? all i see are the tokico ones and i couldnt find any info about them. Also are the shocks different for teh 350/35c? Like i was thinking of Z shocks/struts up front and 35c springs inthe rear.
jsimonk
Dec 22, 2023 03:49 PM
laksjd84
Steering & Suspension
16
Jul 12, 2017 12:22 AM
tiguy99
Mar 1, 2016 11:42 AM
xplosive1
Aug 1, 2015 03:01 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
