DO i need a camber kit
Old Apr 25, 2007 | 09:35 PM
06infin's Avatar
i have a 06 g coupe 5at with 20 inch stern wheels with toyo prox t1r 275/35 zr20 noticed that the inside of the tires is wearing. The left rear tire has tred on the left side of the tire and almost bald on the right side. The right rear has tred on the right side of the tire and almost bald on the left. On the front right is starting to look like the back tire. The driver side is best tire out of all of them. Both sides are good.
Old Apr 25, 2007 | 09:52 PM
SkyBlueG35's Avatar
my car does the same thing and its been aligned twice and is on stock wheels and falken 452 tires
Old Apr 25, 2007 | 10:26 PM
BadBoy06's Avatar
when is the last time your ride has been on a machine?
Drop = camber kit in most cases
Old Apr 25, 2007 | 10:36 PM
SkyBlueG35's Avatar
mine does the odd wear pattern too the driver side tire is about half worn and the rest need replacing especially the right rear
Old Apr 25, 2007 | 11:47 PM
Calvin's Avatar
Overglorified Altima
our cars are made to have some negative camber. more wear on the insides of the tires is normal. if you're not lowered, you should easily be within factory specs.
Old Apr 26, 2007 | 09:20 PM
SkyBlueG35's Avatar
im on tokico D-spec with eibach lowering springs and a camber kit that was installed with the lowering kit
Old Apr 27, 2007 | 04:08 PM
Conscons's Avatar
i have a question as well, if i am going to install Tokico D-spec + S - Tech . do i need a camber kit ?? i believe S-Tech springs only drop like 1.5 ' with a factory 19" rims
Old Apr 27, 2007 | 05:22 PM
Calvin's Avatar
^^honestly, everyone who drops their car should get a camber kit (if their intentions are to save their tires). unless youre dropping it like < 0.5" or something..
Old Apr 27, 2007 | 05:44 PM
Conscons's Avatar
but i thought it will help if i change the shocks
Old Apr 27, 2007 | 05:49 PM
Calvin's Avatar
shocks wont help you adjust camber..
Old Apr 27, 2007 | 05:57 PM
ttrank's Avatar
Grocery getter
No one "needs" a camber kit.
But when you lower your car it increases your negative camber so your braking performance is hurt and your tires will wear out faster on the insides.
Everyone who lowers their car should get a camber kit.
Old Apr 27, 2007 | 06:03 PM
Calvin's Avatar
Originally Posted by ttrank
But when you lower your car it reduces your negative camber
dont you increase negative camber when lowering the car?
if lowering the car reduces negative camber, i wasted money on my camber kits!
Old Apr 27, 2007 | 06:16 PM
ttrank's Avatar
Grocery getter
LOL
I was typing too fast and didn't read it over before I posted.
You can always do like the drift cars and use camber kits to increase your negative camber! UMS Tuning just did a bunch of work on the K Sport 240SX and it has the most negative camber I have ever seen!! About half of the 255 on the rear was dirty from the ground, the rest was not even touching.
Old Apr 28, 2007 | 04:41 PM
EEjiggapin0's Avatar
if you're dropping a car on z stech and zdspecs would you need camber kits for the front and the rear?
Old Apr 29, 2007 | 11:16 AM
Conscons's Avatar
read the post above~~~~
