n e one running camber kit w/ volk gts
Apr 30, 2007 | 02:36 PM
i recently got my volk gt-s and i was told not to use any camber kits. is this true? im lowered on prokits and my offests are +17/+18 with 245/35/19 and 275/35/19
Reply 0
Apr 30, 2007 | 02:37 PM
plus my fenders are shaved in the rear
Reply 0
Apr 30, 2007 | 02:39 PM
who told you not to use camber kits? i've put camber kits on a z with volks and had no problems with it.
-GP-
Reply 0
Apr 30, 2007 | 02:44 PM
i dont see how your wheels would affect your need for a camber kit.
Reply 0
Apr 30, 2007 | 02:56 PM
i got the rims at F1 and they advised me not to get them in fear that they would rub, but i guess they don't.....thanks
Reply 0
Apr 30, 2007 | 03:10 PM
Just bump the camber up until you have a few mm of clearance upon suspension compression. As long as the wheel tucks then you are fine
Reply 0
Apr 30, 2007 | 05:22 PM
Quote: i got the rims at F1 and they advised me not to get them in fear that they would rub, but i guess they don't.....thanks
if youre dropped low enough/have a very aggressive offset/have meaty tires, then you may need to run an aggressive camber to avoid rubbing. your tires arent considerably meaty, so you should be fine with a camber kit. if any rubbing occurs, just run a lil more neg camber than usual.
Reply 0
