just got used rims help
Old May 1, 2007 | 05:37 PM
Graphic35's Avatar
sold
Old May 1, 2007 | 05:44 PM
ttrank's Avatar
Grocery getter
What are the specs of the wheels? The only reason you would need spacers is to clear your brakes.
Old May 1, 2007 | 05:46 PM
RocketG35's Avatar
Why do I bother to DIY???
you need to find out what offset your new wheels are and then what width the wheel is...and then get spacers for them to push the wheel out to the fender edge and avoid possible inner rubbing.
Depending if you drive a coupe or a sedan...the offsets really vary. Not sure if the 07 sedan is different.
Look on the back side of the wheel, sometimes the offset can be found on a label on imprinted onto the back of the spoke or hub.
Old May 1, 2007 | 05:55 PM
BadBoy06's Avatar
just what he said^^^^..you need more info
Old May 1, 2007 | 06:30 PM
Graphic35's Avatar
ok i just went to my garage here are the pix of the offsets and stuff
Old May 1, 2007 | 06:32 PM
Jeff92se's Avatar
Red Card Crew
Uh, the 5x120 and 5x112 aren't going to fit.
Old May 1, 2007 | 06:34 PM
Graphic35's Avatar
it says 5x120 5x112 and 5x114 on all the rims on each spoke
Old May 1, 2007 | 07:04 PM
akachi's Avatar
those aren't offsets.. those are bolt pattern
Old May 1, 2007 | 07:08 PM
codeflux's Avatar
i see stupid people
Old May 1, 2007 | 07:09 PM
Graphic35's Avatar
Originally Posted by codeflux
i see stupid people
bro im new to this **** iight no need for ur usless comments!!!
dseet
Oct 11, 2015 12:40 AM
gprabhu
19 Inch
Oct 2, 2015 05:55 PM
dcsbh1
Oct 1, 2015 03:15 PM
Patrick Bovee
Oct 1, 2015 10:42 AM
inexorable
17 Inch
Sep 24, 2015 10:43 AM
