Help 20" Wheel Owners! Should I lower my car? Any rubbing issues I can face?
Old May 6, 2007 | 09:19 PM
Concealed StrateG35's Avatar
Okay so my friend has an 06 G35C with 20" wheels but is NOT lowered, stock springs. It sits low in the rear already but in the front it definitely needs a drop.
I'm scared that on my car same thing will happen, rear sits low already, so if I lowered it I'm probably going to rub in the rear?
I ordered DPE S-20 20x9 front and 20x10 rear. (offset will be decided by DPE)
Lowering kit I'm yet undecided (so far it's between 350Z H-tech, 350Z Swift Sport Machs, and Eibach Pro Kit)
Let me know what you guys are lowered on, does it rub? Any type of problems? Camber issues?
Thanks!
This here is my car but NOT MY WHEELS(it's just a photoshop) But you can still see how these 20" wheels there is hardly any gap in the rear and it's not even lowered! The front looks horrible, but look at the rear
Old May 6, 2007 | 09:32 PM
2drwild's Avatar
Got me a SPC camber kit the rear has 20x 10.5 and the tires are 285/30 r 20. I have s techs with 3/4 spring cut..no issues..except speed bumps that take a day to climb there are some big ones then I scrape....
Old May 7, 2007 | 04:14 AM
Do you think SPC makes better camber kits than stillen and any other camber kit brand out there?
Old May 7, 2007 | 12:27 PM
2drwild's Avatar
I went with SPC because a lot of people told me they were worth the money..
Old May 7, 2007 | 02:19 PM
Calvin's Avatar
Overglorified Altima
the spc kit is the same as the eibach kit...the eibach kit is cheaper.
but these are the two best rear camber correction kits out there.
Old May 7, 2007 | 03:09 PM
terrycs's Avatar
SPC is actually Eibach's supplier.
Old May 7, 2007 | 03:45 PM
I'm going to have 20" should I go with Eibach Pro Kit for G35 or the pro kit for 350Z ?
Old May 8, 2007 | 04:02 PM
Anyone else?
Old May 8, 2007 | 04:44 PM
jclit's Avatar
20's shoudl not rub, it really depends on the offset and tire width. Im sure youll be fine with running 275 in the back
Old May 8, 2007 | 05:01 PM
Is this considering that the car will be lowered, or are you saying they shouldnt rub on stock springs?
Old May 8, 2007 | 05:05 PM
ttrank's Avatar
Grocery getter
Did you let DPE know you are going to lower the car? The offsets of the wheels will decide whether they rub or not more than anything else.
Old May 8, 2007 | 05:09 PM
jclit's Avatar
It shouldnt rub at all.. I have tein Z stechs
Old May 8, 2007 | 06:49 PM
What are your offsets? And do you have tein s-techs for g35 or 350z ?
Karnicle
Jul 23, 2015 05:08 AM
Soumilg
Jul 18, 2015 12:33 PM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
