Adjusting rear coilovers...
Old May 14, 2007 | 03:29 PM
FIGGAZ's Avatar
I'm a long time reader of this forum, and have received a ton of great information by simply reading posts. I haven't posted yet, because frankly, I'm a noob and don't have much to add, but recently I discovered a problem that does not seem to have been adequately addressed in the forum.
I bought some adjustable coilovers and need to soften up the rears a bit, but I don't have easy access to the tools required to remove the shocks. I saw a dude at the autocross with extenders on his rears so that he's able to adjust them without taking the shocks out, but I never asked him where he bought them and haven't seen the guy since.
Has anyone got a setup where they can adjust their rear coillovers from inside the trunk? Did you have to drill a hole in the metal to get the extension down into the top of the shock?
If anyone has seen a good solution to this problem or knows where to by these shock adjuster extensions I would love to hear from you....
~FIGGAZ
Old May 14, 2007 | 03:37 PM
izmir41500's Avatar
G35driver Addict
which coilovers do you have?
Old May 14, 2007 | 03:44 PM
driftGT350's Avatar
^^^ good starting point =)
Old May 14, 2007 | 03:50 PM
FIGGAZ's Avatar
Sorry, I didn't think that was important because I was under the impression that they all adjusted the same way, but I have the KSport Kontrol Pro's
LINK to KSports on Ebay
Old May 14, 2007 | 08:46 PM
Rphillips6487's Avatar
ebays not the best way to start off addressing a problem man
Old May 14, 2007 | 08:58 PM
ttrank's Avatar
Grocery getter
I know Tokico makes extensions for their struts. I have the EDFC on mine so it done by a stepper motor on the top of each via a controller.
mjfenix
Aug 17, 2017 05:49 AM
derres
Aug 28, 2015 03:27 PM
linedr89
Aug 17, 2015 05:11 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
netcbc
Jul 24, 2015 11:25 AM
