Brembo Brothers, replacement options.
Old May 17, 2007 | 06:52 PM
fbw5595's Avatar
I have to replace my rotors and pads for my brakes. I have compiled a list and pricing of this maintenance. I don’t care that the total is +$2,400. I just want to know if it is the right path to go. Here is what I have planned.
$178 -Hawk HPS (F&R)
$1520 - StopTech AeroRotors (F&R)
$173 – StopTech SS Brake Lines
$ 45 – Dot3 Brake Fluid
$500- labor
$2416 – Total
Do I need to do the rotors in the back? The back rotors are $836.
Should I just get a BBK? What should I do with the back brakes if I do?
Thanks for your efforts.
Old May 18, 2007 | 12:17 AM
g35ctuner's Avatar
damn! 5OO Labor!
Old May 18, 2007 | 12:30 AM
fbw5595's Avatar
That quote was not from the dealership. I am sure they want more.
Old May 18, 2007 | 11:57 AM
dklau33's Avatar
It should take any good shop only about 2-3 hours tops to replace pads, rotors, lines, and bleed. 500 is outrageous. Let me ask you why you need the Stoptech 2-piece aerorotors. Are you getting them for the look? Weight savings? Plan on doing track events?
Old May 18, 2007 | 02:36 PM
fbw5595's Avatar
^The look and rotational mass reduction.
Old May 18, 2007 | 06:12 PM
The HACK's Avatar
RacingBrake rotors are more affordable. For $2,500 you're paying enough to buy a big brake kit with fixed calieprs.
Old May 18, 2007 | 06:31 PM
fbw5595's Avatar
I don't see that. Care to show me?
Old May 18, 2007 | 06:33 PM
The HACK's Avatar
http://www.racingbrake.com/INFINITI_G35_s/211.htm
Old May 19, 2007 | 01:08 PM
dklau33's Avatar
Wrong link. He's looking for 2 piece replacment rotors. Heres the right one.
http://www.racingbrake.com/INFINITI_s/520.htm
Significantly cheaper than Stoptechs Aerorotors, about $500 less. If money is no object then I'd stick with the Stoptechs since they're proven.
Old May 20, 2007 | 02:23 AM
fbw5595's Avatar
^Stoptechs are lighter too.
Old May 21, 2007 | 10:33 PM
636Racer's Avatar
by how much?
I know you can inquire about having RB making 3pc rotors that uses a composite hat. I read on the corvette forums that they weigh in at 17.5lbs for the Corvettes.
Old May 21, 2007 | 10:44 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
where are you located fbw? if you're anywhere in Socal i can install all that for you for $140
-GP-
Old May 22, 2007 | 01:43 AM
nghiars's Avatar
-GP-
much better and more reasonable price...
Old May 22, 2007 | 01:46 AM
ttrank's Avatar
Grocery getter
The oem rear brakes are good for most track use if you get a good 330mm 4 or 6 pot BBK and good pads.
Old May 28, 2007 | 11:10 PM
fbw5595's Avatar
-GP-
I wish I was in Cali. This forum makes me want to move there. I am located in PA.
