View Poll Results: Which should I get first
Hotchski Sway Bars
68.97%
SPC Front Camber Kit
31.03%
Voters: 29. You may not vote on this poll
Hotchski Sway Bars or Front Camber Kit???
Old May 18, 2007 | 02:36 AM
engs12's Avatar
I recently just got tein basic installed. My order for the spc rear camber kit has just arrived. Here's the problem, I want sway bars but should I get the front camber kit first because of uneven tire wear. Is the camber kit necessary for the fronts?
Old May 18, 2007 | 02:39 AM
Calvin's Avatar
Overglorified Altima
...depends how much you are dropped and for bad your negative camber is...
if it's really bad...well then get the a-arms. if it's not bad, go with the sway bars...
front camber correction kits are only "necessary" if you can't live with uneven tire wear. at that point, you have to decide how quickly they will wear depending on how much negative camber you've gone and your driving patterns.
Old May 18, 2007 | 02:55 AM
engs12's Avatar
I'm dropped at 1.5in. in the fronts. How bad is tire wear compared to the rear?
Old May 18, 2007 | 02:56 AM
Calvin's Avatar
what are your alignment specs..?
i personally would rather save my tires first.
Old May 18, 2007 | 02:58 AM
Skaterbasist's Avatar
Retired SuperMod
Priorities first.
You have a 1.5 inch drop, so the camber kit is a "must" in my opinion.
I plan on buying the camber kit & coilovers at the same time to be exact, when the time comes.
Old May 18, 2007 | 03:00 AM
engs12's Avatar
Haven't got it aligned yet. I want to install the rear camber first. But its also pending on my decision to do the fronts also. Saving my tires would benefit me in the long run. I guess front camber it is.
Old May 18, 2007 | 09:13 AM
ron4row2's Avatar
I think you should save the tires.
jsimonk
Dec 22, 2023 03:49 PM
rezendvous420
May 31, 2020 01:26 PM
Th611
Oct 27, 2015 03:48 PM
wuppiedog
Aug 7, 2015 11:16 AM
nascarbuff17
Jul 16, 2015 10:23 AM
