Do you need a camber kit with TEIN S-Techs?
Old May 19, 2007 | 03:11 PM
DFaz's Avatar
For those of you who are sporint TEIN S-Tech Springs for the G, do you need to get camber kits with the 1.5 drop the springs give?
I am in the market for springs and want am close to getting the S-Tech and want to know as much about em as I can.
If you have them, tell me what you think. Also are you rubbing with 18's, if any at all?
Old May 19, 2007 | 03:13 PM
805g's Avatar
i have stechs as well as tokico adjustable shocks. Camber kit is needed.
no rubbing
Old May 19, 2007 | 03:26 PM
Pepper's Avatar
if you dont want abnormal tire wear then yes... a camber kit is needed. i rub lightly on large dips in the road but thats because my offset is really aggressive.
Old May 19, 2007 | 03:51 PM
Q45tech's Avatar
Anytime you lower the body you need to compensate for additional negative camber BECAUSE the oem was designed for a specific body height above the ground.
Old May 20, 2007 | 01:33 PM
gary c's Avatar
Lowered with S-Techs........
Of course this is only true with our G35's! Most cars have enough ajustment
so you don't have to spend major $ on suspension parts. I figure with good
coilovers and all the other parts to get my alignment back to factory specs
it will cost me around $3K......but if I install H-Techs with new shocks I
could get away with less than $700!
Old May 20, 2007 | 03:11 PM
ballisticus's Avatar
I have the Eibach Prokit and my camber was right at the spec limit after re-align. 20000 miles later w/ proper tire rotations and no problems with tires or anything else. 1-1.25" drop is about all you can do and still avoid the camber kit.
Old May 20, 2007 | 05:35 PM
strcdan's Avatar
god damn thats good to hear! i just threw the s techs on the other day!
Old Jun 4, 2007 | 10:09 AM
strcdan's Avatar
just got the allignment and it came out great. I have 1.9 camber in the front thats all
Old Jun 4, 2007 | 08:00 PM
Q45tech's Avatar
Great? Tires are designed for -0.5 to -0.75 degrees STATIC wny the oem points out NOMINAL.
Machine Head
Sep 4, 2015 07:22 PM
mikemf8
Sep 3, 2015 08:01 PM
NohoG35revup
Aug 22, 2015 12:13 PM
socalg35x
Aug 7, 2015 09:36 AM
nascarbuff17
Jul 16, 2015 10:23 AM
