Anyone Running Wider Falken FK-452's On OEM 18" Rims?
Old May 22, 2007 | 03:42 AM
partyman66's Avatar
As mentioned in the title, I was wondering if anyone here is running a wider-than-OEM Falken FK-452 on their OEM 18" rims.. and if so, what size are you using up front and in the rear? Any issues with rubbing or the VDC system screwing up?
I'm probably going to get these tires, and I would like to go slightly wider, particularly since people seem to say that these tires have almoste no protective lip and provide poor rim protection against curb rash.
Thanks!
Old Jun 10, 2007 | 03:37 PM
partyman66's Avatar
Bump?
I was thinking of going with 255/45/18 in rear and 245/40/18 up front.
OEM Michilin PilotSport specs are as follows:
225/45/18 Michilin PS Front: 25.8" Diameter, 8.8" Section Width
245/45/18 Michilin PS Rear: 26.7" Diameter, 9.6" Section Width
OEM-Sized Falken FK452 Specs:
225/45/18 Front: 26.0" Diameter, 8.9" Section Width
245/45/18 Rear: 26.7" Diameter, 9.6" Section Width
Plus Sized Falken FK452 specs that I'm considering:
245/40/18 Front: 25.8" Diameter, 9.5" Section Width
255/45/18 Rear: 27.1" Diameter, 10.1" Section Width
Do you guys think I'll have issues with VDC running this setup? I could also consider going with the 255's in the rear and the 225/45/18 Falkens up front, since the falkens seem to run about 2/10" taller in diameter than their equivalently sized Michilin counterparts.
Does anyone have any idea about what the formula for the difference between front and rear tire rotation/size is that Nissan/Infiniti actually uses to calculate when to kick off VDC? I think I remember reading somewhere on another sight(my350Z?) that it's something like a +/- 3% difference from stock circumference is acceptable, but I'm not sure if that's an accurate claim by those guys or not.
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
bTanz
Oct 15, 2015 02:31 PM
itschuckster
Jul 25, 2015 08:07 AM
CrazyLogic219
Jul 23, 2015 10:58 AM
