Recommendations for lowering springs please :)
Old Jun 9, 2007 | 03:38 PM
vtb11's Avatar
I'm looking for some lowering springs... I'd be willing to pay a bit extra for higher quality or brand, but I still want to keep the price down.. soooo, if you have a reco, please put brand, price, and link if you know a cheap place for them
oh, and i'd prefer not to lower it toooo much... i dont want to die over speed bumps.. like .8" in front and 1.x" in the back? my 04 has 18's right now
much thanks!
Old Jun 9, 2007 | 04:06 PM
Calvin's Avatar
Overglorified Altima
need more info please.
what are your intentions for these springs? just for looks?
do you prefer a softer or stiffer ride?
have you researched camber correction kits at all? how much are you willing to spend on camber correction kits, if any at all?
Old Jun 9, 2007 | 09:05 PM
vtb11's Avatar
umm, id like to say both looks and a softer ride... im not sure how much i'd spend, i think its more like whats available and the general range.
i really havent much time to research on chamber kits, but if theyre not much more than springs and give better results, i dont mind going for them
sorry that may not be enough info for you, but i dont have a great knowledge of what to expect
im thinking under 300 but once again, variable depending on teh benefits to cost ratio
thanks!
Old Jun 9, 2007 | 09:33 PM
izmir41500's Avatar
G35driver Addict
if you're goin lower than 1" than you'll prolly want to invest in a camber kit to save your rear tires. most don't do anything up front.
Old Jun 9, 2007 | 09:34 PM
Calvin's Avatar
300 bucks will barely get you springs/install. the rear camber kit will be about 250-300 installed - depending where you go.
the h-techs are going to provide you with a subtle/conservative drop and are pretty soft..
Old Jun 9, 2007 | 09:39 PM
izmir41500's Avatar
G35driver Addict
why does the rear camber kit cost so much to get installed. it's just a couple bolts per side and drilling a hole right?
Old Jun 10, 2007 | 12:25 AM
vtb11's Avatar
well, i dont think i want to lower more than 1" because I want to keep above the ground a fair amount.. i found these 2 spring sets, for $180... what do you guys think?
Tein S-Tech Springs are an excellent step towards suspension tuning. They offer a 1.2" drop in the front and a 0.9" drop in the rear for a more aggressive appearance. Their spring rate is:
Front: 6.4 kg/mm / 358 lbs/in
Rear: 4.9 kg/mm / 274 lbs/in
Tein H-Tech Springs offer a perfect combination of lowering, handling, and comfort. H-Tech springs are not as aggressive as other brands and models but still offer you a lowered ride with better handling, with an emphasis on ride comfort.
They offer a 0.6" drop in the front and a 0.3" drop in the rear for a slightly more aggressive appearance while keeping you well above the ground. Their spring rate is:
Front: 5.8 kg/mm / 324 lbs/in
Rear: 4.7 kg/mm / 263 lbs/in
same brand, but just mostly wondering if .6, .3" drops are even worth it..
that, and izmir noted that i needed chamber kit if lowering more than 1"... the first kit lowers the front 1.2 but not the back... would i still need a kit?
thanks!
Old Jun 10, 2007 | 05:19 PM
Andrew37's Avatar
i just bought eibach pro-kit... ive had eibach springs in the past and was very happy with them. The drop is around 1.2" if i recall correctly.
Old Jun 10, 2007 | 05:33 PM
Calvin's Avatar
^^eibachs will dump your car.
Old Jun 10, 2007 | 06:06 PM
Andrew37's Avatar
dump? as in.... lower a lot? or dump as in... they are garbage?
my buddy has the sportlines on his and its a pretty big drop but the prokit is fairly conservative.
Old Jun 10, 2007 | 06:32 PM
Calvin's Avatar
350z h techs are conservative.
the eibach kit has a tendency to sag over time, from what i've seen. it's a pretty aggressive drop, in my experiences.
Old Jun 10, 2007 | 07:13 PM
vtb11's Avatar
well, for my purposes, were the ones i posted a bit ago alright and reliable enough to use? will i need chamber kits for either one of them?
Old Jun 10, 2007 | 08:36 PM
Calvin's Avatar
the s techs are a pretty aggressive drop...and you'll wanna camber kit - more than likely.
the h techs are very conservative...chances are that you won't need a camber kit, but note that you'll have a little more wear on your tires. but imo, a camber it is so cheap (for the rear at least) that it will pay for itself soon enough.
jsimonk
Dec 22, 2023 03:49 PM
privatecorye
Steering & Suspension
May 31, 2016 01:56 AM
StreetStandard
Suspension-Vendor
Jan 18, 2016 03:36 PM
nosam1g
Aug 22, 2015 11:58 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
