GTSPEC STRUT BAR...read here
Originally Posted by aHero4Eternity
wth? what is with the release of all these new strut bars? looks similar to the arc/nrg one...with the bracket and all...
i wonder how much it'll be.............
Originally Posted by Dan_K
Actually that looks better, since there is no adjustment and no way for the bar to ride up during hard cornering. But, knowing Stillen, it will cost a lot.
depending on cost and computability with plenum spacers, i may switch to the stillen bar...
but serious...what's with all these new strut bars recently? how come no one made them before?
Too bad this Stillen version (and all the other bent aluminum ones) are just that aluminum
Like I said, I have bent severall aluminum STB's on the car before, prototypes and otherwise (even some being sold right now
Knowing what I do about how much, and how hard these G35 front midship designed cars flex, I would not go with anything less than good quality steele for this front STB....... trust me.
Damn, looks like I still have to keep on making my (very first one out) version of these STB's, untill someone steps up and makes a worthy one. Oh well..........
) Knowing what I do about how much, and how hard these G35 front midship designed cars flex, I would not go with anything less than good quality steele for this front STB....... trust me.
You can pre-order the Stillen from Intense Motorsports now for 139.00 for a mid June delivery
http://www.intensepower.com/stfrupsttobr.html
hmmm, is it time to ditch my strut bar? O.o
i don't know my metals...so tell me what that means, scott.
the site says it's "304 Stainless Steel Brace"
304 stainless is good material, not too bad, but that Stillen STB pictured IS NOT 304 stainless, not at all. It IS aluminum (T6 6061 most likely) So, not sure what the final product will be made of, but I hope it is not another aluminum one.
question...is 304 stainless steel an (in)expensive material? i mean...the stb is less than 150 bucks. if 304 ss is fairly pricey, then it probably is aluminum afterall. but if it's cheap, then there's a hope.
How do you qualify your design? What makes it better or worse than all the other STBs out there? Was any sort of FEA done on it (or even a run-to-failure test) and compared to the other STBs (material-wise and strength-wise)?
Yes. 304SS is stronger than AL6061T6 but for our application, going with SS may be overkill (and at the same time going with AL may be insufficient). So without any real comparative testing with all of the STBs in the market one can't really say that one STB is better than the other.
ENVautoDetailing.com
Originally Posted by nooooorb
wa2good -
-GP-
