? Tein S Tech ?
Old Jun 5, 2007 | 08:39 AM
BLKed OUT G's Avatar
? Tein S Tech ?
for all ya'll with the TEIN S TECH lowering springs did you also purchase a chamber kit as well???? if so which kind???
Old Jun 5, 2007 | 11:24 AM
Calvin's Avatar
Overglorified Altima
this exact question has been asked before.
a couple of people have been able to get back into spec in the rear, but the vast majority has not.
you don't need camber kits...only if you want your tires to last.
go with the spc/eibach rear kit. the front is going to be outta spec. but you can probably live with it.
Old Jun 5, 2007 | 11:25 AM
805g's Avatar
i had to purchase a camber kit.
2003 - g35 - coupe - tokico shocks, and s-techs. Had to get spc a arms.
Old Jun 5, 2007 | 01:43 PM
vegaseric's Avatar
I've got S-Techs and I was able to get the rear in spec. The front has got a bit of negative camber and it tends to wear the insides of my tires.
Old Jun 5, 2007 | 01:53 PM
redlude97's Avatar
what were your specs?
Old Jun 5, 2007 | 02:30 PM
BayAreaRefuGz's Avatar
i fly low
i have g35 s-techs
i aligned my wheels myself. my rears cambers are -2.25 (L/R) (still out of spec, but should do) with 0.08 toe i think, i cant remember. the front cambers i cant do much to it, but the toe is .10. dont take my word for the toe (f/r) to be exact, but i remember my rear cambers because i was having trouble aligning them. i had so much trouble i remember what were the numbers i was trying to set it to..
Old Jun 5, 2007 | 02:31 PM
i fly low
i know you're asking the other dude for his specs right after the drop.. my rear cambers after the drop, before the alignment was (L)-2.689 (R) -2.777
Old Jun 5, 2007 | 02:40 PM
redlude97's Avatar
Originally Posted by BayAreaRefuGz
i have g35 s-techs
Invest in some rear camber arms, you should be under -1.7 for camber. Your toe values seem good though
Old Jun 5, 2007 | 07:10 PM
vegaseric's Avatar
I'll have to check that after I get home...
Old Jun 5, 2007 | 08:39 PM
i have g35 s-techs
Where did u get your camber kit from??
Old Jun 6, 2007 | 01:21 PM
i fly low
no kits, just alignment.
the rear already comes with a camber/toe adjustment. it's a big bolt that's on the lower arm of the rear. it's where the rear springs sits on. i actually was looking at THMotorsports for camber kits (F/R) but i think on the fine print it said that it doesnt support the tein s/h-techs
Old Jun 6, 2007 | 01:30 PM
redlude97's Avatar
what do you mean? camber kits work with all springs
Old Jun 7, 2007 | 04:39 PM
i fly low
weird.. i remember reading somewhere here on the boards about THM doesnt support tein s/h tech drops.. i dont know, i looked all over for it where it says that. but i guess not? sorry..
KruZZe
Feb 27, 2023 05:04 PM
prinny
Nov 22, 2015 11:07 PM
AJC128
Nov 1, 2015 11:55 AM
bigmike
Sep 17, 2015 01:58 PM
