Bearing by the rear differential is leaking?... (PIC)
Old Jun 13, 2007 | 06:42 PM
codeflux's Avatar
Originally Posted by THX723
That's not the part you're looking for. #7 is one of the two internal pinion bearings.
****... what am i looking for, then?...
Old Jun 13, 2007 | 06:44 PM
THX723's Avatar
G Kreuzer
Well, as they said ... I don't believe there's a part number for it.
Old Jun 13, 2007 | 07:11 PM
sfarrah's Avatar
When I spoke with Nissan they told me I needed to buy an entire new subframe. Not sure if anything has changed since I installed the solids and that was maybe a year ago.
Old Jan 10, 2008 | 09:39 AM
waijai's Avatar
i.love.gold
bumping an old thread....while installing my new hubs and wheel bearings last night, I saw the differential bushing leaking. Anyone else have experience w/ the solid SPL one?
detriments of not replacing it?
Old Jan 10, 2008 | 12:18 PM
ttrank's Avatar
Grocery getter
I'm going to look into mine when my car is up on the rack next month. I'll know more then.
As for the solid one, you will get a lot more drivetrain noise and vibration but otherwise it's a good choice.
Old Jan 10, 2008 | 12:25 PM
codeflux's Avatar
well i still haven't replaced mine. let it burn!
Old Jan 10, 2008 | 08:32 PM
Scrooge's Avatar
The Picture I see is blurry. Can you get a better pic. Cause I got the part number for the bearing (#7) 381200C000(Rear) and 381400C000(front) for the rear. I got this off all data.
Old Jan 10, 2008 | 09:01 PM
codeflux's Avatar
that would require me crawling under the car.
Old Mar 30, 2009 | 06:05 PM
drew313's Avatar
I was changing my rotors and pads last weekend and noticed my diff bushing is leaking too. Has anybody replaced theirs with the OEM part? How much did it cost? Are there any drawbacks for not replacing it?
Old Mar 30, 2009 | 06:17 PM
codeflux's Avatar
doesn't appear to be easily replaceable - i just let it leak. so far no [other] problems.
Old Mar 30, 2009 | 06:22 PM
sfarrah's Avatar
When it went bad on my 350Z they only sold an entire subframe, they didn't sell the bushing separately. Not sure if it's the same on the g35 but I'm guessing it's a safe bet.
Old Mar 30, 2009 | 06:46 PM
drew313's Avatar
Did you end up replacing the subframe? How much did it cost? Seems like a lot of labor involved.
Old Mar 30, 2009 | 06:52 PM
Q45tech's Avatar
Replacing leaky rear subframes has been a normal situation since the 1990 Q45. Eventually everyone of them wears out and leaks silicone isolation fluid. Of course the early models were more robust and lasted 10-12 years.
Old Mar 30, 2009 | 07:07 PM
sfarrah's Avatar
Didn't replace the subframe, I put in the solid bushings from from SPL so I'd never have to worry about it again.
Old Mar 30, 2009 | 09:05 PM
  #30
ttrank's Avatar
Grocery getter
I'm going with an SPL solid bushing too.
