Help: Crooked rear wheel due to accident
Old Jun 10, 2007 | 05:17 PM
6mt2005's Avatar
Due to an accident the bottom part of my right rear wheel was pointing inward(pictured below). After taking the wheel off the only damaged part I could find was the lateral arm back(pictured below) I replaced it thinking that should solve the problem. Now the wheel points inward towards the rear(pictured below) I thought maybe the lower control arm(it holds the spring) might be causing the new problem but upon close inspection I couldn't find anything wrong with it. I'm not sure what part needs to be replaced. Can anyone offer any advice.
thanks
Attached Thumbnails Help: Crooked rear wheel due to accident-wheel-before.jpg   Help: Crooked rear wheel due to accident-photo-0092.jpg   Help: Crooked rear wheel due to accident-photo-0093.jpg
Old Jun 10, 2007 | 05:18 PM
Devil Dog's Avatar
Positive camber fo yo ***!
Old Jun 11, 2007 | 12:24 AM
6mt2005's Avatar
positive camber
I thought a positive camber was when the top of the wheel is titled away from the car which went away after I replaced the lateral arm back. The wheel now tilts sideways towards the rear as shown in the 3rd picture of my first post.
Old Jun 11, 2007 | 12:31 AM
speedracerg35's Avatar
if i were you, i would take it to a shop before you do any more damage to the internasl in the rear of the car. i would bet that there are a lot of things you cant see are pushed out of whack.
Old Jun 11, 2007 | 02:23 AM
in2win's Avatar
looks like axle damage, bent wheels studs
Old Jun 11, 2007 | 02:38 PM
Mountian Pirate's Avatar
The dangers of drifting...lol
Old Jun 11, 2007 | 03:06 PM
redlude97's Avatar
might be the radius arm as well, post some pics of the underside of your suspension so we can get a better look
Old Jun 11, 2007 | 08:56 PM
Maciuniu's Avatar
Yea dude post some more pictures bettet resolution with no wheel preferably from behind and under the car.(had the same **** happen to me )
Old Jun 12, 2007 | 03:33 AM
madscientist's Avatar
tell us what you were doing, that might help to diagnose.
Old Jun 12, 2007 | 03:36 AM
BayAreaRefuGz's Avatar
i fly low
that's what i was thinking.. no dents on the fenders.. only rim bent to a +camber. looks like drifting gone wrong!
Old Jun 12, 2007 | 03:47 AM
6mt2005's Avatar
pics & vid with no wheel
video (8mb)
http://home.comcast.net/~acula/g35_rear_wheel.mpg
I took a bunch of photos and put them all here
http://www.flickr.com/photos/8901834@N08/
thanks for the help
Old Jun 12, 2007 | 01:17 PM
legend921's Avatar
I think you should take it to an alignment shop to get it on a rack. Even the slightest bend on the arm can generate that kind of toe. Or you could have just adjusted your toe when you went and swapped your lateral arm.
Old Jun 12, 2007 | 01:30 PM
LjN_728's Avatar
um...rather than DIY, I'd take it to the mechanic and get some professional advice. If the axle's bent, this will just be the beginning of your problems. What did you do again?
Old Jun 13, 2007 | 06:47 PM
filipm's Avatar
did you check to see if your strut is in line, you could have bent the actual shock..... just my two cents
f
p.s. my guess is that he ran into a curb or something simple like that.....
Old Aug 20, 2007 | 12:22 PM
agamvark's Avatar
all too frequent
Howdy guys:
It looks like others have experienced what I did over the weekend. My drift went bad and I smacked the driver rear wheel into curb at @ 35mph. Wheel is bent lower in and under.
Haven't checked everything (axle, rods, etc.) but anyone have an idea of worse case scenario estimate I can expect from the shop?
Thanks
rezendvous420
May 31, 2020 01:26 PM
shavedcrx
20 Inch
Aug 7, 2015 04:14 AM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
Bean_VQ35DE
Jul 22, 2015 07:06 PM
