Scott [Relentless Strut Bar]
Old Aug 18, 2007 | 05:43 PM
EricIsKlumzyee's Avatar
Well I've had this thing since 2006 and havnt installed it yet =PPPP
Anyways I HAVE NO IDEA HOW TO INSTALL THIS THING =(
Well I can get everything to fit but do i have to relocate the power steering reservoir?? the bracket is in the way also when I install it I do not have enough room to put the bar on o.O
Anyone have a detailed pix?
I need to know where the 3rd arm goes. (the 3 piece bar is screwed on at 6 points.. 3 on each side.. 4 of these 6 goes on the nuts for the strut.. the other 2 are in question for me)
help
- Eric
Old Aug 18, 2007 | 05:55 PM
SFLG35's Avatar
FGC President
has anyone heard from scott lately??
i sent him a pm weeks ago asking for some install instructions, and havent heard anything. does anyone have the instructions that came with the strut bar they can send me?
Old Aug 18, 2007 | 07:07 PM
what do you need help on? I have his personal cell but I dont want to bug him on a weekend lol
- Eric
626-636-6678
Old Aug 18, 2007 | 10:11 PM
SFLG35's Avatar
FGC President
dont need help as of yet cause i am out of town, but i am gettin a bar from my buddy who says that it is made wrong and doesnt fit at all. i dont believe him so i am goin to try to install it on my car, so i just wanted to look at some instructions and see what the install was goin to be like
Old Aug 18, 2007 | 10:23 PM
Calvin's Avatar
Overglorified Altima
eric, you damn noob!
https://g35driver.com/forums/brakes-suspension-diy/106339-diy-vrt-strut-tower-brace-install-notes-pics.html
Old Aug 18, 2007 | 11:08 PM
machavez702's Avatar
I am assuming this is the same as the VRT bar I have. The 5th & 6th mount point requires some work. You have to remove the wheels, drop the springs and remove a screws at the top. Then you replace with the new longer screws and re-install the springs. The screw is long enough to stick out past the square nut (accessible from the engine bay). The 5th & 6th point slide over the screw and you install the 2 new nuts that came with the kit. Points 1-4 use the stock nuts. (you can do 1 side at a time).
Old Aug 19, 2007 | 12:11 PM
Tonys-G's Avatar
I also had a problem with the bracket mount on the passenger side geting in the way of the power steering bracket, lucky I had a friend who was good at fabricating, he made a small extension which he then bent and grinded to fit perfectly, you can see it better in these two pics
hope this helps give you guys ideas to get around the issue
Old Aug 20, 2007 | 01:55 PM
I'm working on modifying the bracket so the steering resevoir is just going to be held on with two bolts and moved..
Thanks!! =)
Old Aug 20, 2007 | 02:06 PM
btw i just read teh DIY the JWT pop charger has some clearance issue i had to play around with the thing to get it to fit
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
Claudiu
V36 Brakes, Suspension, Wheels & Tires
Mar 10, 2018 11:38 AM
Picture Share
Feb 4, 2018 12:41 PM
prinny
Nov 22, 2015 11:07 PM
