Changing Rear Brakes
Old Jun 24, 2007 | 09:21 PM
Goonz SVT's Avatar
Brakes Changing Rear Brakes
My brother needs his rears rotors and pads replaced, I dont want him to go to the stealership because I can do it for him. However my fear is the ebrake cable or if there is one in the rear calipers. Im good with changing out front brakes because that is cake, its the rear ones I always am shaky on. Is it hard to take out the caliper in the rear and also is there a special tool needed to compress the rear pads? Is dealing with ebrake cable in the back a big pita? Also I couldnt find a DIY on the rear brakes, thanks guys!
Old Jun 24, 2007 | 09:29 PM
Nismo G's Avatar
No, its pretty straight forward. I think you will need a 15mm socket (not quiet sure on that) to take the 2 bolts that hold the caliper secure off. Then the rotor just slides right off and swap in the new rotor and pads tighten everything back up and then pump the brakes and you should be good to go.
-Sean
Old Jun 24, 2007 | 09:40 PM
GGRJR's Avatar
Back on the G isn't much more difficult than front. Like Nismo G said, the only issue might be getting the rotors off, a large rubber hammer helps, some times they are stuck.
Old Jun 24, 2007 | 10:10 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
the back is the same as the front. You'll need a 14mm socket/wrench and a 7/8 or 22mm socket/wrench.
-GP-
Old Jun 24, 2007 | 10:22 PM
Dakkerz's Avatar
This link may help. The descriptions on the picture aren't so easy to read, but its a decent write up.
https://g35driver.com/forums/showthr...63#post1347463
Old Jun 25, 2007 | 09:54 AM
Goonz SVT's Avatar
awesome, all in all if its the same as the front almost, shouldnt take me more then an hour then I hope..sweet@!
kinetek
Aug 3, 2015 04:25 PM
atk08
Jul 30, 2015 03:12 PM
sahizzle110
Jul 29, 2015 11:36 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
emorehs
Jul 17, 2015 09:45 AM
