Stillen Sways Installed
#31
on
Originally Posted by G35fromPA
Look, it's a nice try throwing in "weight transfer" to try and confuse the situation, but I didn't make that up. In general, it is absolutely correct to say that, all other variables being held constant (as in the case being discussed here of just adding or adjusting sway bars), the stiffer end of the car will lose traction first in a turn. That table is a an old standby used by racers everywhere to set up cars. I'm sorry if you never covered it in your "racing school" but it's pretty well known.
#32
Originally Posted by XKR
You are coming on here telling people to set up with Soft in front and Medium or Hard in rear and that is OK.
In fact, you advised someone that setting the front to medium and the rear to soft would reduce understeer (https://g35driver.com/forums/showpos...3&postcount=2), and the fact is you are wrong. That setup is similar to the stock balance, and promotes further understeer.
What you mean "confuse the situation?" The only thing confused here is you. There is more to consider than just Soft Medium or hard. A person that sets up a car with Soft up front and Medium in Rear with stock Sway bars will get a different response than a person with the same setup but with stiffer sway bars. You said Google?? I think that is where you got your driving experience .
#33
This is that post you responded to. Note the word High Speed. I am sure you could not mistake that statement for referring to Autocross. Your THEORY FOR SCRUBBING OFF SPEED WOULD NOT APPLY WHILE HEADING TO A WALL OR TIRE WIRE AT High SPEED GET IT
Here are a few pics of me and a friend from 2 years ago:
<img src="http://www.streetneeds.com/uploads/twinturbonet/AX2_big.jpg">
<img src="http://www.streetneeds.com/uploads/twinturbonet/AX3_big.jpg">
<img src="http://www.streetneeds.com/uploads/twinturbonet/AX4.jpg">
See any understeer/oversteer or weight transfer there? I thought so...
Also, I said AVERAGE TOP SPEED OF AUTO CROSS. NOT TOP SPEED YOU GET THAT ALSO Not everyone goes 60mph. If one person goes 60 mph and most of the other go 50 or 40.....the AVERAGE SPEED IS NOT 60. In formula one, some cars reach 205mph but the average speed is not 205mph.....it could be 190 or 195 or less.
I apologize to the rest of you for posting on here like this.
http://en.wikipedia.org/wiki/Autocross
"Autocross tends to place more emphasis on car handling and driver skill than on sheer horsepower...Speeds are slower in absolute terms when compared to other forms of motorsports, usually not exceeding highway speeds, but the activity level (measured in discrete turns per minute) can be higher than even Formula One due to the large number of elements packed into each course...In addition to being a national-level motorsport in its own right, autocrossing is a good way to learn skills that transfer to road racing, as drivers learn vehicle control and club ethics...autocross speeds can reach over 60 mph (100 km/h)"
#34
You think those guys on the street with 1000 hp Supras would be happy to see their car dip when they hit the brakes and get light in the rear after hitting 180+ ?
#35
on
I love this thread. Somehow I thought that this site started pealing off.
Ok. Stillen vs. OEM ’03 sedan a.sway bars: +7%, +51% and +70% (soft, med, stiff)
OP, cooldog45 in post 1 stated:
Basically, he transferred 44% roll stiffness to the rear.
XKR, in post 2 you stated:
Please explain. I like to learn.
Then you went on explaining how oversteer is safer. For you!
I then asked you in post 13:
Now, I understand where you are coming from, but I don’t care - this thread was about OP setup.
Originally Posted by cooldog45
I have them set on soft front and med rear and I love it.
The way you have it setup, you are promoting "Understeer". You should have the medium in the front and the soft in rear. Or stiff in the front and medium in rear.
Originally Posted by dovla
Did I understand correctly:
While cornering, events ahead in front of you are forcing you to slow down, so you lift, causing the oversteer and then you brake?
Or you oversteer and then you lift to brake?
Are you drifter? Thanks
#36
G Kreuzer
on
Here’s a simplified guide to sway bar tuning (to address the original topic),
<!--[if !supportLineBreakNewLine]-->
<!--[endif]--> To increase understeer or reduce oversteer:<o></o>
Add front bar and/or reduce rear bar
To increase oversteer or reduce understeer:<o></o>
Reduce front bar and/or increase rear bar
Also note that increasing the front bar stiffness has a positive affect on initial turn-in response (e.g. react on a dime). Go too far with that, you will quickly transition to the understeering state shortly after the turn-in. Likewise, going too far with the rear bar setting could result in snap oversteer. It is up to you to find your ideal setup. But be wary that what feels great at 50% or even 80% effort could be more than a handful at above 90%. Tread cautiously if you like to experiment at the local canyon w. VDC off.
Now to touch up on the others …
<o></o>
The general consensus in the industry is that reasonable understeer is preferred and deemed safer than reasonable oversteer for the average John and Jane Doe drivers. The assumption is that the mass majority of the driving population are not well versed in the concept of proper countersteer evasive manuever (which includes throttle modulation) but are instinctively programmed to lift (off the gas) during a surprise. The latter (lifting) is helpful during understeer but not for oversteer.
<o></o>
Having said that … the above scenario is certainly not all encompassing. It’s no secret well trained drivers generally prefer oversteer over understeer, because they are allowed the possibility to “drift” out of the situation; often effortlessly. However there is a point in which too much is simply too much even for the veterans before physics simply takes over. In such case, excessive oversteer fairs no better than excessive understeer. It’s game over for both. I am of the latter group, so I like my car tending towards oversteer, while the girlfriend gets the car that likes to push (aka understeer).
<o>
</o>regarding car control …
<o></o>
If the car is understeering the last thing you’d really want to do is to touch the brakes. This is indeed what they would teach you at the driving schools. It isn’t a hard concept to understand either. Understeering is none other than the front tires having met and exceeded their road holding capacity and therefore unable to continue track the car towards the intended path. During this delicate state, nailing the brakes will almost always end up locking the front tires, further reducing their road holding capacity - into the wall you go. The corrective action should be lift (off the throttle), which not only trims the speed until it is below threshold (to regain traction), the onset deceleration also has an effect of transferring weight forward (onto the front tires) and thereby temporarily increasing the threshold.
<o></o>
I will note there are other techniques that one could employ to force the car out of an advanced understeer (e.g. hand brake, clutching, gas/brake pumps + steering), but they are highly evolved maneuvers that most drivers (and even advanced drivers) wouldn’t think of trying. The previously prescribed lift-off strategy is among the most fundamental and easiest car control technique to counter 99% of the understeer conditions.<o></o>
<o></o>
<o></o>
<o>
<o></o>
<o></o>
#38
Dan...every car is different, and even 2 cars of the same exact model, can also react differently. But one rule of thumb is "Never set up a car where the shocks and springs are softer in the front and Harder in the rear.
You ever see a... for example, an old Caddy when you slam on the brakes, the front dips? That dramatic transferal of weight prevents steering control under braking when the rear is stiffer than the front.
From my experience (depending on the car and driver the effect of control you want) Medium Front & Medium Rear.... Medium Front & Soft Rear.... Hard front & Medium Rear are the settings we use for achieving a neutral feel to a little Oversteer to alot of Oversteer.
I agree that in the G/Z, a stiffer front and softer rear spring is the way to go. A race team (can't remember their name, but its on my350z) published this a couple years ago and came out with their own spring line with a stiffer front than rear.
#39
#40
G Kreuzer
on
Originally Posted by Dan_K
Interesting, but can this theory be applied to almost any sports car? From all the resources I have read, including ones from a couple suspension companies (like Tokico), it indicated that if you want oversteer, make the rear stiffer and then the front softer. Which makes sense, since you don't want any "bend" in the side-to-side suspension which will give the tires that extra grip. I am strictly talking about the sway bars here, not springs/shocks.
Some of XKR's statements need further qualifying (no pun intended), while others are regrettably off base. I shall return and elaborate. I am currently being summoned to the cockpit test lab. Will be back in a couple hours or so. Yes, I'm at work too!
#41
G Kreuzer
on
Originally Posted by Nismo G
If this forum only had more logical debates like this then i think everyone on here would learn a lot more. Most of the threads turn into pissing matches, but i have learned some great stuff in this thread.
-Sean
-Sean
The fact of the matter is no one loves to be told their wrong (myself included). Belief in oneself is a powerful thing and often a good thing. However what makes or breaks is one's ability to acknowledge they are either mislead, confused, or simply wrong. Debate is a way to the realization.
It was only the other day that I realized I had dropped the ***** on the subject of "final drive ratio affecting speedo" for our car. Bummer! Made a mistake, admitted it, and moved on. ... such is life.
#42
Red Card Crew
Great info. this is how I've understood it also.
Also note that increasing the front bar stiffness has a positive affect on initial turn-in response (e.g. react on a dime). Go too far with that, you will quickly transition to the understeering state shortly after. Likewise, going too far with the rear bar setting could result in snap oversteer. It is up to you to find your ideal setup. But be wary that what feels great at 50% or even 80% effort could be more than a handful at above 90%. Tread cautiously if you like to experiment at the local canyon w. VDC off.
<o></o>
<o></o>
Having said that … the above scenario is certainly not all encompassing. It’s no secret well trained drivers generally prefer oversteer over understeer, because they are allowed the possibility to “drift” out of the situation; often effortlessly. However there is a point in which too much is simply too much even for the veterans before physics simply takes over. In such case, excessive oversteer fairs no better than excessive understeer. It’s game over for both. I am of the latter group, so I like my car tending towards oversteer, while the girlfriend gets the car that likes to push.
<o>
<o></o>
<o></o>
<o></o>
<o></o>
<o>
<o></o>
<o></o>
#43
G Kreuzer
on
In trying to hold up my end of the bargain, I was doctoring up an elaborate (promised earlier), but I think we are already in harmony here. I will leave it as is for now. The last thing I want to do is come off as trying to crucify any individual. So until someone expresses the need to be expanded on a particular, I will let my fingers go to sleep.
Regards,
Regards,
#44
Regards,
Regards,
