which brakes wear down first?
Old Jul 9, 2007 | 07:07 PM
kernel's Avatar
SEC > Big 12
Brakes which brakes wear down first?
which brakes wear down first, the front or rear?
I had a Maxima before my G and I def. replaced the front more ofen than the rear. I just got my G about a month ago, was told the front brakes needed to be replaced, took it to the dealer and they said my rotors were too thin to be turned and would need to be replaced. I replaced the front brakes/rotors and I still hear the noise I did previously and now I think its my rear brakes.
I guess I'm wondering if rear wear down faster in the G b/c its RWD compared to my Maxima which was FWD.
Old Jul 9, 2007 | 07:19 PM
Talon32's Avatar
The front normally wear down almost twice as fast as the front. I have had cars that went through two sets of front pads before the rear pads were done.
Another thing to look for is how much more brake dust is on the front rims than the back ones and that will tell you how much faster the fronts are wearing.
Old Jul 9, 2007 | 07:35 PM
tekknikal's Avatar
the front usually wear much quicker than the rear.
btw i suggest you get replacement pads/rotors from stoptech, much cheper than oem and equal/better quality imo
Old Jul 9, 2007 | 08:20 PM
kernel's Avatar
SEC > Big 12
Ok, just wanted to make sure it wasn't different b/c this was RWD. If i do get another set of OEM, it def. won't be from my dealer, way too expensive. My dad use to own a dealership so he can help me change them and I'm just going to get rotors/pads off the net (unfortunately I haven't had a lot of luck finding ones for the rear that weren't basically as much as my dealer was charging).
Old Jul 16, 2007 | 10:52 PM
tekknikal's Avatar
^check with stoptech, g35parts.com, mynismo.com, as well as forum sponsors, marketplace sales, etc...
Old Jul 16, 2007 | 11:05 PM
RichardxG35's Avatar
for me the rear wear out faster then the front.. i replace my rear pads with OEM nissan pads work good for me
Old Jul 16, 2007 | 11:40 PM
kernel's Avatar
SEC > Big 12
yeah I think i'm going to get some Hawk ceramic pads from mynismo.com, not a bad deal unless someone knows of a sponsor/other site thats cheaper.
Old Jul 17, 2007 | 08:58 AM
Talon32's Avatar
Ricardxg35- do your back pads wear faster since you have an awd G?
Old Jul 17, 2007 | 01:05 PM
TheKnite's Avatar
I have Brembos and my rears wore out faster than the fronts. After years of going aftermarket, I now only go OEM for many reasons. I found great prices on everythingg35.com, grubbs performance, and chad. search for them.
Old Jul 17, 2007 | 01:15 PM
kevink's Avatar
Previous car, front brakes at 102K, rear drums at 85K. But different technologies involved
On my 04 G35, front brakes at 37500. Rear brakes still original at 41K.
Old Jul 17, 2007 | 01:33 PM
mubay's Avatar
front pads !
Old Jul 17, 2007 | 03:17 PM
G35fromPA's Avatar
Typically front brakes wear out faster because weight transfers to the front under braking, which means the front brakes do most of the work.
Old Jul 17, 2007 | 07:58 PM
dovla's Avatar
+1 what G35fromPA said, unless you are dragging (riding) the brakes.
My Brembo OEM pads, after ~20K miles, inside rear were done while front had plenty left. Replaced all pads with B-Force pads and now I am, ~15K later, on my third set of front B-Force pads while still on initial B-Force pads in the rear. However my driving style during last 15K miles have been very different than first 20K miles.
Old Jul 18, 2007 | 05:52 PM
Q45tech's Avatar
Since 1989 Infiniti has used above average rear brake pressure to squeek the last foot of stopping distances out..........this worked especially well with VLSD and SHARP ABS CYCLE TIMING and attack/release points.
On the early Q wear was so close to equal that it was amazing. Unfortunately as they played around with pad compounds to calm whiners [4 different front pad compounds] it oscillated back and forth.
Always interesting to measure rotor temps as a indicator of pad temps to select pads to match temperatures the hotter pad will wear first.
xx7sephiroth7xx
Brakes
May 3, 2023 07:07 PM
seagrasser
May 3, 2022 09:43 AM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
Hawk196
Sep 10, 2015 10:37 AM
NJ6MT
Sep 10, 2015 08:40 AM
