Brake Help!!!
Old Jul 12, 2007 | 12:22 AM
BlackHammer's Avatar
Brake Help!!!
Hey guys I really need your help here. I think I need to get some new brakes but I have a couple questions first. Please share all your knowledge, I would appreciate it!!!
1) Do aftermarket brakes such as Brembo, etc. last longer between replacements than stock brakes?
2) Would Brembos fit on my car? 2003 G35 Coupe with 19X8.5 in the front and 19X10 in the rear?
3) How much does it cost to replace the pads?
4) Can you put Brembo calipers on your existing rotors?
Old Jul 12, 2007 | 03:46 PM
PotomacG's Avatar
The '03 stock pads wore very quickly. There are dozens of different aftermarket pads and rotors, some wear more quickly than others.
Did your Coupe come with Brembos to begin with? Unless you are going to upgrade to a BBK or something like that, you want to get the parts that match your current OEM setup. Brembo probably has replacement rotors that fit your Coupe.
Anywhere from $50 to $150 for front and rear pads plus labor.
You would not replace the calipers unless you are upgrading to a BBK.
Old Jul 12, 2007 | 08:14 PM
The HACK's Avatar
Depending on how they're built and who built them. There are crappy aftermarket suppliers and there are good, name-brand aftermarket suppliers that built better rotors with better cooling design or cryo-treated/heat treated materials for longer life. But you pay more for that. Obviously, good stuff does not come cheap. Brembo, Powerdisc/ATE, StopTECH, and RacingBrake all make excellent replacement rotors. Hawk, Axxis, and Cobalt Friction all make good pads.
If you're asking about replacement rotors, Brembo replacement rotors for NONE BREMBO brakes exist and they'll fit. If you're asking about used Brembo kits from say, a 350Z, yes they'll most likely fit. If you're asking about Brembo's aftermarket 4 and 6 piston kits (or 8), like their 332 or 355mm rotor Grand Tourismo kits, then it depends heavily on your wheel spoke design AND offset.
Cost of the pad. Ranges anywhere from $65/axle to $200/axle depending on what kind of pad you're using.
No. You'll need the right sized rotors in addition to the Brembo calipers and caliper carriers. Basically you'll need the entire brake system from a donor car.
Old Jul 13, 2007 | 12:19 AM
Thanks
Thanks guys!!!
Picture Share
Feb 4, 2018 12:41 PM
Gabe83714
Oct 6, 2015 06:40 AM
dcsbh1
Oct 1, 2015 03:15 PM
alinero718
Sep 27, 2015 09:35 PM
